Snow Peak Addiction
Honu
lost on the mainland
the webbing is a lot bigger than I thought cool :)
mine is just on some 1 inch stuff :) ahhahah
a nice burgundy red to match the SP tents and stuff would also be cool :)
Yuman Desert Rat
If I ever come across any of that color I'll be sure to grab it. I'm going to start working on the version that stows flat in the empty space of the IGT. I measured and can fit 10 poles in there so let me know what you would need?
Dave Bennett
Adventurist
I finally picked up a Baja Burner Li and I'm wondering how those of you that have them transport/store them. It seems like Snow Peak makes a specialized carrying case for every other product in their line EXCEPT this burner. I have this bag for the bbq box, but don't know that it'd work for the baja as well: http://www.snowpeak.com/bib-case-ug-080.html
While not shown on this page: http://www.snowpeak.com/accessories/utility-bags.html , they DO make a bag that matches the "Multi Container" line that is a PERFECT fit for the baja burner - I purchased one at OEX this year. I'd call the Snow Peak store in Portland and inquire, they can get one I'm sure of it.
Yuman Desert Rat
20131014_134239-1.jpg20131014_134224-1.jpg20131014_133959-1.jpg20131014_124818.jpgJust had a bloke from down under request a set of roll up straps that hold 8 IGT legs. The "inside" the IGT version that will hold up to (10) size 660 legs in the IGT 3 and size 830 for the IGT 4 respectively, coming soon.
Yuman Desert Rat
Okay I have the first set of "inside the IGT " straps finished and bound for the land down under. With the legs stored using these; table panels can be stacked against both sides and secured using straps that I have in development. I also invented a nifty set of isolators that eliminates the rattling noise from inside the leg sockets. ... more to come...20131015_100015-1.jpg
Honu
send me a PM or let me know what you want for those :)
much nicer looking than my setup :)
Okay I have the first set of "inside the IGT " straps finished and bound for the land down under. With the legs stored using these table panels can be stacked against both sides and secured using straps that I have in development. I also invented a nifty set of isolators that eliminates the rattling noise from inside the leg sockets. ... more to come...View attachment 191346
V45W_Proto2.5
