LETS SEE YOUR TRAILERS!!!!
XVENTURE TRAILERS
Supporting Sponsor - XVENTURE Trailers
The Elevating Rack System is comprised of stainless rectangular tubes that go down through the hollow side walls of the cargo bed and sit on the chassis at the bottom and fastened at the top of the cargo bed shoulder. Then 3 x 5/8 thick aluminum bar stock fit precisely into those tubes and has holes along its length allowing various heights to be set using the lock pin. At one end of where the elevators attach to the rack are slots allowing the elevator coupling to slide approximately 3" as the distance between the front and rear vertical beam increases as you raise or lower one end.
Currently this is a manual lift system and one person can raise and lower the rack. We are working on mechanical actuators that will do the lift. Should have it available in 60 days.
richjeeps
Eagle
Pictures or drawings of this please!
java
Thanks! That's what it looked like, but i was secretly hoping there was a actuator in there somewhere.
Gator
That is a work of art!
Lator.....
MtnClimber
Ready To Explore!
Fabulous pix! What brand is your tent? I'm really digging the fly over the ladder. Mt Tepui Kukenam doesn't have quite the extensive overhang like yours...wish it did for those rainy/dewy days.
corprin
Thank you. Tent is a Mombassa Overland Plus. I know CVT and ARB both sell the same tent type under their branding as well.
vati kaki
I think I, m done for now, added the can holders on fenders , but may not use them got 4 ,5 gal water inside
vati kaki
my shower
abctrash
