Aye it's taking shape!
The lifting portion has now got fairly heavy - not ridiculously so, but sufficiently that I can't easily shift it on my own. I need to get assistance to move it around and turn it, so that slows me down a bit.
Currently doing the pre-priming cleaning up. I"m putting some filler on the front and rear overlap joints where the thin roof alloy overlaps the thicker alloy frame, just to make it a wee bit more 'clean' looking. The sides will eventually be covered by the roof-rack assembly so should not be visible. Once I get a mildish day I can prime and topcoat it.
My problem then is actually assembling it!
I'll need four people to get the lifting section onto the top of the lower perimeter frame. Once its there a friend has offered me a barn to use for a day or two - I can put a pulley over a beam and hoist the end of the lifting section up and over far enough to reveal the hinge end so I can seal and screw the hinge down. That's a pretty crucial part as it needs doing properly to prevent leaks, and I need it securely supported so it doesn't fall or crush anyone in the process. Its not hugely heavy, but its 9' long and a few pounds on the end of a 9' lever exerts a considerable amount of force.
Don't want to see several months of work trashed courtesy of uncontrolled gravitational acceleration (and subsequent deceleration!)
