Making a ifting roof on a 110
I seem to be unable to attach images any more, same on both my computers.
Is there a problem or something I'm doing wrong? (I'm doing what I've done on all the previous posts, which have worked - odd).
*Just tried again and when I click the add image button my screen greys out but the upload function dialog does not appear. Any suggestions?
Perhaps log off - log in will help.
These forum software seem to have their own ideas at times...
Have logged out, logged in, logged out, logged in and on and on and on....... What is odd is that both a laptop and a desktop machine exhibit the same problem which suggests its a forum-specific problem, but I cant imagine what it is.
Edit - and have emailed two of the mods but no response, but that's fair enough as it's christmas and they may be otherwise occupied!
Managed to get a bit done before Christmas was upon us, and did it inside as the weather is sliding into proper winter.
Got the ply lining and pine bracing installed. The strip of pine nearest this end is there for three reasons:
1) there's a joint in the ply sheet (the roof is 9' long, and sheets are only 8'),
2) and as this is where we'll climb up to get onto the sleeping platform it will provide a firm fixing point for a couple of handles or a bar that can be used to pull up on,
3) and which will also be useful for physically pushing the lifting roof up, and pulling it down again.
Also the roof width is just over 8" wider than a 4' sheet of ply so putting the pine strips either side mean I only need one sheet of ply. The rebate (groove) in the sides of the pine allow the ply to be held at the correct thickness to give an even finish throughout the roof length. They also provide a smooth, clean, strong fixing point for the top of the fabric sides and allow the top of the gas strut to be firmly fastened to them, and will spread the not-inconsiderable load on the strut (which would have been a point-load on one small spot on the roof) along the full length of the side. They keep the roof from flexing too much as well. So well worth fitting.
Because of the length/angle of the gas struts and the fact they have to lie horizontal when closed they will only operate when they reach 12 degrees so that first push up is important and a good firm fixing point is essential. The metal strengthening plates will be countersunk and can be filled or veneered over with some thin slices of pine.
As I've still got the lower section of the roof sitting on the top of the 110 I thought it might be prudent to take it off as snow was forecast. It needed cleaning out anyway as it had filled up with dead leaves, crisp packets and any other rubbish the recent gales could toss about. Its now in a generous neighbour's garage where I'll rub it down and etch prime it sometime soon.
As the 110 was 'topless' I thought I'd use it to go over to the west coast a few days ago to see my mum. We have a small VW but the 110 is safer in the winter and the road was very very wet with giant lakes on it hiding deep potholes (yes this is the main road west!). On the way back I took a detour which is on a small rural single track road which is quieter and would avoid me having to negotiate the swerving cars trying to avoid the big puddles on the main road in the dark, and it had started to sleet which looked like it might turn to snow (although not forecast to do so until the following morning). However this is a hill road and has a high pass but I thought we'd get over before the snow started in earnest.
As we hit the first bit of hill we found a Land Rover Freelander demolished in a ditch. It had done a 360 spin and gone into a tree backwards/sideways but because of its rearwards trajectory had saved the occupants, an elderly couple on holiday to visit relatives for Christmas, from serious injury. You can see the tree imprint in the side of their vehicle.
They were shaken but ok, so I offered to take them to their destination about another 25 miles, and on my route. So we emptied all their stuff into the 110 and waited for the Police to arrive. By the time they got there it was dark and snowing in earnest. We then had the main mountain pass to negotiate in a raging blizzard (sorry no pictures as it was rather full-on). Got to the top of the pass and could see another vehicle coming up the other side so stopped, pulled in and flashed for them to come on. But they stopped. On the hill. In a 2wd hire car. And were stuck. It was a family on holiday from England and caught unawares. My tow line was buried under the elderly folks gear mountain so I thought I'd use my shovel and cleared as much snow as I could down to the tarmac and they were able to inch up, but we had a long long way to go and the snow was getting worse in the 30 mph wind. But then a new Land Rover Disco with the local garage owner in it came up, pulled out a strop, would it round something underneath the small car and I got to see terrain response working in earnest. He pulled the Ford to the top of the hill with no drama, no slipping and with an ease that was quite remarkable. We all got home safely. Thank you Land Rover.
Managed to get the lower section primed and painted in my neighbour's garage over the last week. One can of 500ml Etch Primer (Acid8) and 6 cans 300ml white auto paint did the job. Fumes were diabolical.
I bought a proper 3M mask and goggles and could not smell anything whilst doing it, but when I took the mask off outside the smell was grim.
I 'scrubbed' all the surfaces first with the angle grinder using an alloy cleaning disc/pad, then towelled it down and ensured it was clean and dust free. The acid etch primer dries really quickly, in less than half an hour, but I left it for a few days until we had the forecasted mild day, then did the white topcoat.
No idea whether it's right or not but I was advised to do it in a single session, light coats, 15 to 20 minutes between each and continue until complete. Didn't take too long. Left it three days to cure and today carted it out and took it back into my own garden. There are a couple of slight runs but nothing too terrible - not any worse than the cra*p 'professional' paint job that I had done several years ago that's on the rest of the van.
What did I learn doing this? You need a lot of light to see what you're actually doing, and the light needs to be properly angled and able to reveal the texture of the paint (*I did not have one and resorted to a super bright mountaineering LED headtorch). I also chose not to overprime the slightly grey etch primer with a white primer so that I could see where I was painting with the white topcoat - not sure I'd do that again when doing the lifting bit. I think I'll white prime it over the grey etch and make sure I have a load of light to see what I'm doing and where I need to spray.
PS - it is actually white, I've slightly underexposed the images so the paint texture can be seen - if I make the exposure so the paint is 'white' you can't see the detail. And the surface is also speckled with a light shower of rain so those are not bubbles you're seeing! (at least not yet!)
The pairs of small holes visible in various shots in the perimeter raised frame are for the 'ironmongery' - the clips that hold the lifting top down tight to the lower frame, you can see them in the previous posts. I removed them so they didn't get stuffed full of paint.
This is the front end (slope above windscreen).
This is the rear end, with cut-out for the back door. Small hole in the lower corner is for the bolt that fixes it to the original roof - will bore it out to a slightly larger diameter for the final fixings which are all stainless steel.
2eleven
