So I just stopped by Gap-Diagnotic in Canada (I'm spending a couple days in Montreal) and got a IIDTool directly from Patrick.
By the way, Patrick if you read this, I can only thank you for taking time off your vacations and show me how to use this amazing little object.
I used it to lift the truck (just 20mm for now) and it reduced the rubbing of the tires against the frame extensions but I think that it needs another 10mm or so to stop rubbing.
The BFGs are a great choice but I wanted to keep the unsprung weight to a minimum and have a tire that doesn't compromise too much the comfort of the truck
 the price difference was only $60 per tire. The Hankooks come out second on consumer report tests due to their price but are better on ice and snow than all other competitors... I'm French so I initially wanted the BFGs (owned by Michelin) but I'm really impressed by the HKK. Just drove 500 miles on ice and snow in Quebec by -10F and the grip is unbelievable. Sounds like I'm trying to convince you to give them a chance
As far as tire diameter the Hankook are indeed 31.5 vs 31.7 for the BFGs. Really surprised that no one experienced rubbing against the frame in the wheel well... Maybe you'll be lucky too who knows.
Regarding the front calipers I did get the rims powder coated but I doubt I lost that much space with it and the spacers I got are over 30mm at 32mm...
Regarding the LR rims and Compomotives the offset is respectively 53 and 44... Let's not forget that with the LR rims we use the spacers which drastically changes the numbers. I use a 1.25" (32mm) spacer which might correspond to a 21 offset in a way...
Can't wait to hear how it works out for you
Axel
