An Axe - Seriously?
nwoods
Axes never run out of gas...
Boy I don't know about that one. I had to clear a sizable pine tree from a trail a while back, and I was totally spent after whacking away at that thing for an hour or three
crazy
In my relatively short time as a part of this community, I have seen a number of posts and pictures where someone has an axe mounted next to their shovel or hi-lift. To be honest - what for?
-JM
Seriously? What if you're on the trail and your girlfriend won't STHU?
Arlen
After reading the last 49 pages of axe vs no axe vs zombies vs. no zombies...
No one has mentioned my favorite video on care and feeding of an axe, so here you go. It's a bit lengthy, but good work takes time. :)
Anywho, thanks for the fun read!
AFBronco235
Crew Chief
Sorry to resurrect this debated thread, but I've got an ax to grind. (Couldn't help myself)
Actually, I just picked up a 28" Fiskars chopping ax, (as opposed to the splitting ax, yes, there is a difference for those ignorant of ax model and design). It was on sale at the local farm store. I was wondering how everyone else likes the brand. The only concern I'm having is how the head mounts to the shaft. I keep thinking one good ********** on the side of the fiberglass around the head and it will come apart. Am I being overly worried?
As for the debate, I'm with carrying an ax and a small pocket saw. There are times when an ax is needed and times when a saw is needed. A saw doesn't do so well with clearing roots and an ax can't cut in tight places.
BigSwede
The Credible Hulk
Fiskars says it won't break. Ad copy: "◾Inseparable PermaHead™ insert-molded head will not loosen and prevents overstrike breakage"
I have a Fiskars X25 splitting ax that we used last fall to chop a frozen oak tree that was on the trail. While there may have been some issues with our technique, there were certainly none with the axe.
AFBronco235
Crew Chief
I have a Fiskars X26 splitting ax that we used last fall to chop a frozen oak tree that was on the trail. While there may have been some issues with our technique, there were certainly none with the axe.
I saw that on the website, but I'm always cautious. I've only ever known of one company that truly offers to replace a broken product for any reason, weather its a factory defect or not and its not Fiskars. They're "Lifetime Warranty" is limited to factory defects. It offers nothing specific on if the head will separate or not under "abused" conditions. I also saw nothing on the website about using the ax as a striking tool and weather or not that is covered under "regular use" or "abuse".
