Cooper Discoverer S/T Maxx
amo292
Got my 285/70 r17 Cooper Discoverer ST Maxx mounted up on my 2nd gen tundra two weeks ago. So far I like them a lot. They don't hold up so well against New Hampshire clay mud but they clear out really fast.
Hopefully Ill get some more experience with them in the near future to keep you guys updated.
kojackJKU
Autism Family Travellers!
Just placed my order for my second set of 285s. Also ordered American eagle 012 wheels to mount them on.
someday
I finally got these tires a little dirty and I am a VERY pleased with them. I do not go 'mudding' but as u can see, do gather firewood in some 'not so easy access' areas. With my old BFG AT Ko's I would have to get straps and/or the high lift out but the Maxx's just kept digging in. I have literally gotten stuck in 1-2" of slick mud with the BFG but yesterday and today the Maxx's just kept forward momentum and we kept inching along. I was amazed! In the deep mud I had an empty trailer (about 1200 lbs), in the last pic I was 1/2, maybe 3/4 loaded which would be around 2500-3000 lb. Didnt take it loaded down through the deeper mud, but still a lot of long sections on 3-4" of slick mud 10-20 yards long.
someday
OOOPS, I forgot, as u can tell, the raised white lettering look great against the black rims. (😋)
Mauka2Makai
I've accumulated around 12k miles or so on the ST Maxx and couldn't be more pleased. They have more that exceeded my expectations in all terrains... sand, snow, ice, rocks, dirt roads, and daily commuting to include evasive maneuvers on the 405 and hard braking. I have yet to experience them in thick or soupy mud, but can only speculate that they would perform well. The noise levels are a whole lot more friendly than the BFG or Toyos I previously owned... wife is happy about that. Tires are wearing evenly, they are tracking straight and firmly planted at freeway speeds, and no signs of chunking or sidewall cracking. When needed I'll air down to 18-22 psi and have always had positive results. Personally, I love there looks... aggressive yet refined. They are a bit on the heavy side so that is a downfall. I highly recommend these tires and will buy them again in the future.
kojackJKU
Nice cruiser. Yep that is the only downside. weight. but I put everything else before weight. Yes, my jeep will be less "peppy" with the st maxx, but they last so damn long, and grip in everything and on everything.
kb7our
I have a new set of these 255/80R17 on a '14 Jeep Wrangler and dig them a ton except still trying to diagnose a right pull with my local DT that installed them. Already rotated left to right and rear to front but still have a right pull so 2 new tires are on the way to try another pair on the front. Jeep drove fine with stock BFGs after 2.5 AEV lift so something is up with these that I haven't figured out yet. Had alignment checked under warranty with print out and everything is within spec "except" a minor camber issue on the left front which I'll fix with an offset ball joint - Jeep drove straight with this issue present and OEM tires. Coopers ride smooth so balance seems fine, just have to hold the wheel to keep it from going right. We'll see how the 2 new tires do once they arrive as DT has been very accommodating. If they fail I may need to swap to KM2s which I wanted to avoid on this build - I really dig the Coopers in this size. Anyone else have similar issues with their Coopers?
Redline
Likes to Drive and Ride
I have a new set of these 255/80R17 on a '14 Jeep Wrangler and dig them a ton except still trying to diagnose a right pull with my local DT that installed them. Already rotated left to right and rear to front but still have a right pull so 2 new tires are on the way to try another pair on the front. Jeep drove fine with stock BFGs after 2.5 AEV lift so something is up with these that I haven't figured out yet. snip...]
Different tires on some rigs may require different alignment settings to drive 'right/straight', within spec is not enough for all combinations. Both of my more recent truck builds (Toyotas) have needed more cross-caster for most (not all) tires to eliminate a right pull. Close to 1 degree of cross-caster (i.e. 2.5* left. 3.5* right) has been 'normal' for these rigs. With Toyo tires, I was not able to stop the pulling to the right (Toyo MTs are known to pull) no matter how much cross-caster was dialed-in, we tried.
I recently, temporality removed a set of ******** Cepek Mud Country 285s (love the tire) which only needed about 0.5 degrees of cross caster, and installed 255/80R17 S/T MAXX on my 'built' 4Runner. The new tires pulled right until I had a custom alignment performed on this full-time 4WD car (which is factor), to a full 2 degrees of cross caster. Perfect now, untill I go back to the DC MC treads and need to return the caster settings. I knew this was likely going to be a required adjustment because of prior S/T MAXX testing.
kb7our
Interesting...with the AEV drop brackets being at the minimum setting for a 2.5" lift (upper hole on the UCAs), they dial in caster at a 0.2 difference between sides with the left side having more positive caster than the right by design. I may pull off the brackets going back to OEM specs which I am pretty sure is equal castor left and right and see if that fixes the right pull.
Redline
I'd be surprised, a 0.2* deference is a small amount to either feel or correct for a pull, unless you are on the verge of neutral handling with these new tires. If the facotry adjusters are still functional, if it were me I'd see an alignment master who is willing to do what it takes. I'd start with a substantial increase of caster at the right front to help steer the car left. Then a test drive(s) and readjust as needed.
1stDeuce
If kb7our is willing, we're going to try a camber shim on the left instead. Camber and caster both affect pull, and he's so close to neutral that either should make a difference. Oh his solid axle Jeep, it's way easier to do a camber shim than an offset balljoint for caster/camber.
Just curious, you're both experiencing right pulls... Redline, did you ever try turning the right tire around on the rim? (Both sides blackwall, right?) If it's tire construction related, and one is running "backwards", then that should fix it.... then again, if you swapped the fronts side to side, the pull should have gone left at that point, and I know you said it didn't. Man, I wish I knew what was causing this. Doesn't make sense that it's the tire if swapping things around doesn't change it, but there's nothing about the alignment that should be causing much of a pull or drift at all. ???
One thing that it occurs to ask is if the right pull happens if you straddle the yellow line... I wonder if the tall tread is allowing the crown of the road to have more of an effect. The lower profile and lower tread height OEM tires would resist this a little more... ??
BTW, it's a "Pull" if it leaves your lane in less than 3 seconds when you let go of the wheel... If it takes more time than that it's a "Drift". ;)
Chris
1stDeuce
Bad news... the cross caster is built into the axle. You can swap the brackets around all you want and cross caster isn't going to change other than within the tolerance of the machine, which is probably +/-.1 deg on each side... I think the AEV kit was designed to run 4.5 degrees of caster, and you're right there. Don't change the bolt holes, or you'll end up with too much or too little caster, and DW and crappy handling can be the result of that...
Chris
Redline
True, I forgot about that and the caster adjustment flexibility I have on my IFS Toyotas. A camber shim is what Les Schwab Tires typically installs on live-axles Dodges to help with the right pull from Toyo MT tires on those trucks.
I'm not expreicning any pull, my 4Runner is dialed with 2 degress of cross caster. My Tundra is dialed for ******** Cepek FCII treads (and Mickey Thompson MTZs) with 0.9 degrees. I've considered it being contruction related, tread related, wheel related, etc. :) There are many similar posts/threads here on ExPo in older tire threads (approx. 5-6 years ago) with more info about this. Then I was just starting to get a handle on this, I'd previously only owned live-axle 4WDs all my life. Since then I've succesfully used trial and eorror to adjust for diferent tires several times. For the record, about 1.5 years ago Toyo MTs were pulling and/drifting on my '96 F350, a problem I've not had with other tires on that rig; I went back to Maxxis Bighorns.
Maybe once I tried swapping tires on wheels, but mostly I've swapped tires side-to-side in an effort to diagnose (the Tire Rack has a good tutorial on this), and many of my tires have not been blackwall on both sides.
At least in my case, what I'm talking about and have experienced is much more (and more consistent) than a little pull or drift from the painted lines or a pavement seam on the road.
When the pull has been present, it has been as you note, a lane change in about 3 seconds (sometimes less). Even if it was not that bad, and sometimes it was not... On a level road, without wind (I have much wind where I live), I require a better level of driveability from my rigs on-highways. Four seconds would not be okay, and I prefer 6-10 seconds a straight tracking if I can get it. :)
