Sure-Fire Ways to Improve Your Roof Top Tent
32vsnake
Did LED strip lights for the tent.. running off the "house" battery
Better shot of the switch
stingray1300
For those of you that are putting LED lighting inside your tent, don't go overboard. I only have a 2' strip of lights, and it seemed fine at the time, but I've since decided to remove it because its just TOO much light at night.
You can see my install below (its slim but its attached to the center of the top hoop):
I've got my eye on a simple battery powered LED dome light that is intended for a Jeep roll bar.
Can you post a link to the one you're looking at getting?
Thanks!
jesperjes
I've added 2' strips on all three hoops with a dimmer. Yes it can be very bright but with the dimmer it can also be very cozy :)
I've also added a strip on the bottom right by the ladder with a separate switch, this is without the dimmer
Guri
The dimmer is a good idea, is that a PWM dimmer? Looks like a nice item.
This is the light I was looking at getting:
http://www.quadratec.com/products/14018_9001.htm
I'm hoping its a bit dimmer than the full 2' bar. I'm considering relocating the 2' LED bar under the rear tailgate for night time cooking.
I have a control remote dimmer like this one and it is PWM (I saw it with a scope) and it works really good with the LED light I have inside of the tent. You can't see it blinking at all.
T-Rey1
infra
n00b
I have the same dimmer but it does not completely turn off the strip. Once of the leds are still on but very dim
I thought the same exact thing at first after I installed it. The middle button is the power button, if you push and hold the middle button it will turn the lights off.
T-Rey1
Tried that. The lights don't completely shut off till I kill power to the switch
Scottydog13
I had an issue with the ladder being too short and didn't want to add the extension. So killed 2 birds with one stone. I built myself a "front porch" that I can wipe off my shoes prior to placing them in the shoe hammock.
Rattler
Thornton Melon's Kid
compactcamping
I have a much better and stronger design of something similar. I am having them produced soon. They will be sold through a friend's shop. I will post up more details once they are available.
From a DIY perceptive these are easy to make. Strength wise, you'll overload the tent base / track before they would break.
Here are a few different sewn ones that I've done, work nice, but more work to make.
oskarf150
