For those of you that are putting LED lighting inside your tent, don't go overboard. I only have a 2' strip of lights, and it seemed fine at the time, but I've since decided to remove it because its just TOO much light at night.
You can see my install below (its slim but its attached to the center of the top hoop):
I've got my eye on a simple battery powered LED dome light that is intended for a Jeep roll bar.
The dimmer is a good idea, is that a PWM dimmer? Looks like a nice item.
This is the light I was looking at getting:
http://www.quadratec.com/products/14018_9001.htm
I'm hoping its a bit dimmer than the full 2' bar. I'm considering relocating the 2' LED bar under the rear tailgate for night time cooking.
This is the switch I bought and am using for the LED strips inside my RTT. It has a built in dimmer and the switch itself has like 18 different settings built into it, so you can put the lights on disco mode, fade in and out, blinking, and etc....
http://www.ebay.com/itm/130894836881?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
I have the same dimmer but it does not completely turn off the strip. Once of the leds are still on but very dim
I thought the same exact thing at first after I installed it. The middle button is the power button, if you push and hold the middle button it will turn the lights off.
Tried that. The lights don't completely shut off till I kill power to the switch
I borrowed this great idea from another post in the portal:
Made a bunch of these recently and tried them out this past weekend. Worked great.
http://www.expeditionportal.com/forum/threads/130041-Holes-in-RTT-Floor
I have a much better and stronger design of something similar. I am having them produced soon. They will be sold through a friend's shop. I will post up more details once they are available.
