08
(above) The wall plan changed a bit... Taking advantage of the 1x1 curb and moving the hinge as shown, will allow the wall to lay flat to the outside... Here's how it looks closed up to the inside...
(above) The wall upright and vertical...
(above) The wall folded over to the outside... This model doesn't show that there will be 15" of wall laid on top of the 'pods' to eliminate the need for additional wall support when fully open...
(above) The wall, end panels and doors will have this as the core...
(above) The core is light and weak... Fine for a core, but for edge support, wood is bonded to the foam... First it's T & G'd to the core with epoxy...
(above) A fast clamping strategy is stretch wrap... Strong enough for the task...
(above) The other edge was set after the epoxy hardened on the first side... This time, string was wrapped and tensioned stronger than the stretch wrap could provide... After the wood strips were turned upright you could play it like a traditional three string Japanese "guitar"... Twang...
(above) Finally, I'm trying to get this to fit in a nine inch tall drawer... Maybe...
