TerraLiner:12 m Globally Mobile Beach House/Class-A Crossover w 6x6 Hybrid Drivetrain
biotect
Designer
Hi everyone,
I've been following the engineering debate re "Independent Suspension versus Straight Axle" in particular, and E-motor hybrid technologies more generally, with great interest. But I've been staying a bit detached, because I utterly lack the technical and/or engineering expertise to participate fruitfully. It's an interesting debate, because again, it seems that there has been virtually no discussion on any webforum (so far) about the possibility of large hybrid expedition vehicles. And very little discussion here on ExPo. So the territory is wide open for research, speculation, argument, and more research.
Although the engineering involved in hybrid buses and cars is partly applicable to the TerraLiner, it would be great to see more concrete examples of hybrid technology implemented in vehicle types that have to be “tougher”. So far I have posted lots of information about Oshkosh's venture into heavy-duty, off-road hybrid, as well as Pistenbully's pioneering the same in its snow groomers. But if anyone comes across other, concrete examples of hybrid implementation for tough conditions, by all means, please post weblinks and as many images as possible.
I am making this request because discussion of these technologies can get awfully abstract and hypothetical. Whereas concrete examples speak volumes. That's why I posted so much information about the L-ATV and TAK-4 independent suspension, for instance: to show visually that the latest version of TAK-4, called “TAK-4i”, seems to have a resting state that gives the vehicle considerably more center-line clearance than straight-axle. And TAK-4i has an extreme “down” state that is no worse than straight-axle. Those images are pretty hard to argue with. The only possible response (which thjakits already posted), is that straight axles with portals would allow just as much (and no doubt far more) centerline clearance.
Even still, it would also be great to see more concrete examples of bad-road and even off-road capable trucks, military, rally, and otherwise, with independent suspension. NeverEnough mentioned that the lion's share of research and development money is going in this direction, so more examples must exist. And the same with “tough hybrid”: it would be great to see more examples of hybrid technologies developed for vehicles that have to travel bad roads, and/or off-road. That would give the debate some context, a bit of concrete grounding. And images are always great eye-candy.
Strictly speaking, the TerraLiner's design specification is:
1) Driving on paved roads most of the time
2) Driving on “bad roads” perhaps 20 – 30 % of the time
3) Driving truly “off-road” perhaps 5 % of the time, or less
Whereas the Oshkosh L-ATV, for instance, is specified as 70 % off-road. But even still, an extreme military vehicle like the Oshkosh L-ATV can prove instructive, and it would be great to see more examples of hybrid and IS implementations for such demanding conditions.
All best wishes,
Biotect
biotect
Designer
@thjakits:
What do you want to achieve with such toy motors? :)
They are designed to work for a few races and not to last for 100th thousand of miles with long service interval.
The power of 6x37 kW = 222 kW = 302 hp would be at the low end, but the resulting torque at the wheels of 6x 1630Nm = 9,780 Nm is extremely bad for the Terraliner with a weight of 18 t (metric). :rolleyes:
Even my old MAN KAT has a maximum torque at the wheels of about 984 Nm * 2.5 * 6.37 * 1.07 * 6.734 * 1.59 = 179,526 Nm. This means that it has a pulling power from standstill of about 18 t (metric) without burning a clutch, and even that is not enough in some situations.
Regarding necessary power when I do the calculation for my truck I come to the result that I need about 300 kW to do a 3 % incline with constant speed of 80 km/h, which is pretty much that what I get currently. For a 6 % incline and same speed I would already need about 430 kW. On flat surface I need about 170 kW power at a speed of 80 km/h.
Of course Terraliner shouldn't be like a brick as our KAT. For my calculation I took a drag coefficient of 0.6 and a frontal car area of 10 sqm. A drag coefficient of 0.4 would reduce the power on flat surface for 80 km/h to about 154 kW. Bringing down the weight to 12 t would reduce the power to 113 kW.
Shouldn't such a future concept try to save weight as much as possible?
This will also allow to reduce weight on a lot of points of the chassis construction and makes the vehicle more off-road capable.
For a serial hybrid the continuous power of the generator should output at least 1.5 times the continuous power for maintaining highway speed to be able to recharge the battery. As I wrote earlier two of the Jenoptik units would be ok to get enough power. Because of a large battery bank with at least 100 kWh I see no need for an extra generator just for supplying house power. This all is additional weight and room.
In my opinion a gear box with at least 2 gears for the electric motors makes sense, because there is either to low torque at the wheels or the rpm of the electric motor is more than 10,000. It is right that synchronous electric motors deliver torque from standstill and can do high rpm, but the best efficiency is normally in a range of 2000 - 6000 rpm.
For me the biggest question is, whether Terraliner with 10 m length, 18 t weight and loaded with so many features is the way to go. At the moment I don't see how all this features can be packed into the available 10 * 2.5 * 4 = 100 cbm room without making compromises on living and storage room. Especially the last is missing on a lot of expedition vehicles. The vehicles are fully loaded with technical features, but there are only small lockers available for personal cloths and other items. In reality there is even less room available because most of the lowest 0.5 - 1 m is lost to wheels and chassis.
Design and feature list is one point, but converting this to a real construction is a very complicated task, which cannot always be completed. I am sure some features will have to be dropped. Better make a clear priority list first in order not to get lost in the details.
Hi egn,
As always, great to hear from you. Here are some questions, which you are in a particularly good position to answer, given your practical experience driving a large motorhome in unusual conditions, for instance, up a creek bed in Albania....:sombrero:
1. The TerraLiner's Center-Line Clearance?
What would you say should be the ideal center-line clearance of the TerraLiner? 50 cm? 60 cm? or more?
2. Portal Axles? Blue Thunder's Center-Line Clearance?
If you think the center-line clearance should be more than 60 cm, then you would probably favor portal axles, correct? Do you think that the TerraLiner should have portal axles? If not, why not?
It would be great to have your feedback on this particular issue, because it affects the design of the "camper box" of the TerraLiner, very much. Higher centerline clearance, means the tubular space frame starts higher, which might also mean that the camper box floor has to start higher. So having a recommendation from you regarding "ideal" and/or sufficient center-line clearance would be greatly appreciated.
Have you driven many deeply rutted roads with Blue Thunder?
dcp_7663b.jpg stock-footage-uzbekistan-circa-an-old-jeep-passes-on-a-deeply-rutted-road-near-the-aral-sea-uzbe.jpg deep_ruts.jpg
screen-shot-2014-02-18-at-09-16-48.jpg deep-ruts-l.jpg dirt-road-deeply-rutted-used-image.jpg
Has Blue Thunder ever come close to getting stuck, because its center-line clearance was not sufficient?
3. Haf-E's 3 Electric Motor Proposal: Same as Oshkosh
Previously you have made it clear that you favor straight axles, and not independent suspension.
So do you also favor Haf-E's suggestion: 3 separate electric motors, driving three straight axles via mechanical differentials? I am personally very strongly inclined in this direction right now. But on one side thjakits favors hub motors, while on the other, dwh favors the idea of just one big electric motor, perhaps driving a Tatra backbone tube. So what is your current thinking on this question? Clearly, you seem to be against hub motors, probably for the same reasons that Haf-E and optimusprime are against them: hub motors will not be protected from severe vibration and shocks on corrugated bad roads like the Tanami Road in Australia, or the G219 in Tibet.
It's worth noting here that Oshkosh's Propulse hybrid system is set up in exactly the same way as proposed by Haf-E. The relevant pdf is at http://www.oshkoshcorporation.com/pdfs/Oshkosh_ProPulse_drive_brochure.pdf , and is very much worth reading and quoting in full:
Populse drive technology is unmatched in its ability to power severe-duty trucks. It is the only operational system that claws through the most rugged terrain, keeping pace with armor as it delivers the environmental and economic benefits of a hybrid electric drive system.
ProPulse ushers in a new generation of severe-duty trucks. It’s ideal for tactical trucks, homeland security vehicles, disaster relief, and peacekeeping missions. It’s engineered from the ground up to take on the challenges of military service. And it’s no surprise that this technology comes from the one company who builds the toughest, most reliable, most technically advanced trucks in the world – Oshkosh Truck.
ProPulse increases fuel economy up to 40 percent because the diesel engine in the system continuously runs at optimal rpm — significantly more efficient than the maximum rpm usually needed for highway speeds and full payloads. Emissions are also reduced, meeting current and proposed EPA requirements. And the on-board generator offers enough electrical output to power a residential block, airfield,hospital, commandcenter, communications equipment and much more.
There are no batteries to maintain or replace. Less fuel is needed over the life of the truck. The full electrical system lowers torque throughout the drive train, reducing wear and tear on the truck. And the modular design requires fewer spare parts. All of which increase the value of the vehicle by reducing the life-cycle costs.
Propulse allows for a smaller logistics footprint, increasing the mobility and deployability of fighting forces. Lower fuel requirements mean less fuel to transport, while on-board power eliminates the need for cumbersome generators to power field operations.
Energy Storage Unit
In addition, increased readiness is achieved through improved diagnostics that trend performance and track maintenance over the life of the vehicle, predicting maintenance needs more accurately than ever before. The diagnostics also offer real-time operating information and help keep your truck ready for action. And the easy to maintain system has fewer moving parts, no batteries and many commercially available components.
The ProPulse electric drive technology and its diagnostic systems help crews identify issues and keep vehicles at top performance. Advanced safety technology allows the user to discharge all stored energy from the truck, so maintenance crews can work in complete safety. This Safety Maintenance Mode eliminates the need to have specially-trained technicians performing routine vehicle maintenance.
The simplified drive train of ProPulse delivers more power. The diesel engine drives a 335 KW generator that delivers power to electric motors dedicated to each differential. This direct transfer of power eliminates the need for the torque converter, transmission, transfer case, and drive shafts, making the entire system more efficient with fewer moving parts.
The energy storage unit provides extra power for acceleration, deceleration and other functions, and is capable of receiving much higher regeneration energy for highly responsive braking. It delivers the power the truck needs and still maintains fuel efficiency.
The ProPulse system provides the power to traverse the most demanding terrain, and put payloads and electricity where you need it most. It is slated to power the new HEMTT A3, the next generation of air- transportable tactical trucks. And it’s one more way Oshkosh is transforming severe-duty trucks for modern military forces.
I highlighted the most relevant sentences in blue.
Note, however, that although the PDF does not explicitly discuss this, Oshkosh seems to be implementing its TAK-4 Independent Suspension system across its entire product range, including its diesel-electric hybrids. This suggests that there is no "intrinsic" or "necessary" conflict between the three E-motors solution, and IS. The three E-motors do not have to be driving three straight axles.
Like you, Haf-E, thjakits, and a few others, I am also now inclined towards straight axles. But I would still like to hear from campo, about why he strongly favors Independent Suspension for the TerraLiner.
4. The TerraLiner's Power Requirement
According to your calculation, 430 KW should be very sufficient for the electric motors, which is similar to thjakits' rough-ballpark figure of 420 KW for the electric motors. If the electric motors need 430 KW, then wouldn't the diesel engine have to be 645 KW, if the power ratio is 1 to 1.5? In terms of horsepower, that's an 865 HP diesel engine! But two Jenoptik generators would only produce, combined, 120 KW + 120 KW = 240 KW. See http://www.jenoptik.com/en_20083_power_units and http://www.jenoptik.com/en_30134_auxiliary_power_units .
So I am not entirely clear what your argument is here. Are you saying that 300 KW is enough? Or that 430 KW would be better? Is your argument that driving up a 6 % incline for an extended period is very unlikely, so 420 KW or 430 KW is totally unnecessary? However, even 300 KW would not be covered by two Jenoptik generators, which produce only 240 KW. Are you saying that 240 KW should be enough, even though this is less than the current power requirement of Blue Thunder?
However, it is very interesting that you favor the idea of two side-by-side identical generators, instead of one big generator. Any particular reason why? Distributing the weight on two different slide-out trays? Redundancy?
5. Size of the Electric Motors
Now if you favor Haf-E's proposed solution, would you have all electric motors be the same size? Or would you have different electric motors be different sizes? And if so, why?
For what it's worth, the axle format that I have settled on is a standard tandem design as per Blue Thunder: one axle in front, two clustered in the rear. And I am no longer worried about the "breakover" angle, because so many commercial overlanding vehicles have such bad breakover angles. The vehicles used by Dragoman, Oasis, Odyssey, etc. all have breakover angles much worse than the breakover angles in the 6x6's posted earlier in the thread. For further discussion and lots of images, see posts #1027 and #1028 at http://www.expeditionportal.com/for...edition-RV-w-Rigid-Torsion-Free-Frame/page103 , and posts #1068 to #1080 at http://www.expeditionportal.com/for...edition-RV-w-Rigid-Torsion-Free-Frame/page107 and http://www.expeditionportal.com/for...edition-RV-w-Rigid-Torsion-Free-Frame/page108 .
6. TerraLiner Weight Reduction
As for overall weight, my engineering friends are working on those calculations right now.
Remember, because this is a concept vehicle, I can do crazy things like specify that the tubular space-frame will be made out of titanium, perhaps created via the new technology of titanium 3-D printing -- see http://www.3ders.org/articles/20130...st-3d-printed-titanium-fighter-component.html . This was suggested by thjakits in post #825, at http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page83 .
Furthermore, I can specify that the camper box and pop-up will be made out of carbon fiber. Agreed, weight reduction is critical, and as you suggest, would also have a significant impact on the overall power requirement, as well as the TerraLiner's off-road capability.
Did you see the posts earlier in the thread about the new, all-carbon-fiber trailer, called the CR-1? Posts #865 to #867, at http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page87 . Or see http://www.wired.com/2014/04/gct-cr-1/ , http://www.gctrv.com/Global-Caravan-Technologies.php , http://www.gctrv.com/CR-1-Carbon-Fiber-RV.php , http://www.gctrv.com/images/vtour/Salon-vtour/tour.html , http://www.gctrv.com/images/vtour/Kitchen-vtour/tour.html , http://www.gctrv.com/images/vtour/Bedroom-vtour/tour.html , http://www.gctrv.com/images/vtour/Bathroom-vtour/tour.html , http://www.gctrv.com/About-Global-Caravan-Technologies-RV-Manufacturer.php , and http://www.gctrv.com/About-Press.php :
[video=vimeo;88709487]http://vimeo.com/88709487[/video]
A typical 31 foot Airstream Classic Dinette Trailer weighs about 7,174 pounds, whereas the CR-1 is 35 feet long, 7 feet high, and weighs only 6,500 lbs.
In the world of commercial cargo-carrying trailers, Wal-Mart included an all-carbon-fiber trailer made by Great Dane, in its Capstone microturbine-based concept truck -- see http://articles.sae.org/13507/ , http://www.core77.com/blog/material...nels_for_their_supertruck_prototype_27697.asp , http://www.dezeen.com/2014/03/07/walmarts-electric-powered-carbon-fibre-truck-concept/ , http://www.greencarreports.com/news...cept-truck-the-fuel-efficient-future-of-semis , and http://news.walmart.com/news-archive/2014/03/26/walmart-debuts-futuristic-truck :
The last video explains the trailer's construction at great length, which involved a technological collaboration between Fiber-Tech and Milliken -- see http://www.fiber-tech.net , http://www.fiber-tech.net/index.php/product-info/product-info , http://www.fiber-tech.net/index.php/product-info#Transportation , http://www.fiber-tech.net/index.php/showcase , and http://www.fiber-tech.net/index.php/gallery ; and http://www.milliken.com/en-us/Pages/default.aspx , http://www.milliken.com/en-us/pands/Pages/composites.aspx , http://structuralstrengthening.milliken.com/Pages/home.aspx , http://structuralstrengthening.milliken.com/Pages/products-renewwrap.aspx , and http://www.buildingspeed.org/blog/tag/milliken-company/ .
Walmart claims that this is the first all-carbon fiber trailer ever produced, and that the 53-foot long side panels are the largest single pieces of carbon fiber ever manufactured. Wal-Mart trailers normally weigh about 14.400 lbs, whereas this carbon fiber trailer weighs 3000 lbs less, or 11,400 lbs. That's a weight saving of roughly 20 %.
One early, innovative entrant in this market is "Composittrailers" of Belgium, now renamed "Acrosoma", which you can read about at http://www.reinforcedplastics.com/v...e-composite-trailer-to-a-conservative-market/ , http://www.reinforcedplastics.com/view/4666/composittrailer-changes-name-to-acrosoma/ , http://www.compositesworld.com/articles/new-lightweight-trailer-delivers-heavy-duty-performance , http://trailer-bodybuilders.com/archive/ten-percent-weight-reduction-composittrailer , http://www.vdlfibertechindustries.com/?page/5791502/Acrosoma®.aspx , http://www.vdlfibertechindustries.com/?page/5793582/Technology.aspx , http://www.vdlfibertechindustries.com/?page/5792542/Markets+and+Products.aspx , http://www.plast.dk/billeder/Sektioner/Komposit/MicrosoftPowerPoint-JanVerhaegehe.pdf , http://www.vdlfibertechindustries.c...flet_Acrosoma_VDL_Fibertech_Industries_EN.pdf , and http://issuu.com/acrosoma/docs/acr_acrosomapanels_eng_lr?e=3874049/2677937#:
Their trailer with Acrosoma panels weighs 25 % less than an equivalent aluminum or steel model.
For additional initiatives in this direction, see http://www.diabgroup.com/Cases/Tran...ch-Reefer-Trailer-from-TTT-The-Team-Composite , http://www.diabgroup.com/en-GB/Sandwich-technology/Introduction , http://www.diabgroup.com/en-GB/Sandwich-technology/Introduction , http://www.theteam-hamburg.de , http://www.theteam-hamburg.de/pdf/cfrp-zero_emission_reefer_trailer.pdf , and http://www.theteam-hamburg.de/pdf/TheTeam_Messebrochuere_09-2010.pdf ; and http://www.lightweight-structures.c...eight-composite-isothermal-trailer/index.html .
7. Abundant Storage Space
As for storage space, I have a few additional tricks up my sleeve. Almost a year ago I really took to heart all of your thoughts about the problem of designing a TerraLiner to have enough storage space for three or four weeks of boondocking. And not just storage for food, but also enough storage for clothes. A couple full-timing in the TerraLiner will probably want to carry almost as many clothes, and the same variety of clothes, as they would if they had a fixed home. I have been very conscious of this issue, so don't worry, the TerraLiner is being designed with such considerations very much in mind.
"Compromises" will not be necessary, at least not on paper anyway......:sombrero:
8. Battery Bank Size, and Ultracapacitors
Also, thanks for that estimate of the battery bank size: 100 KW. This is roughly the same as the size estimate that my engineering friends gave.
I have been following thjakits' lead about "Dual Carbon" batteries -- see http://www.theatlantic.com/technolo...japan-that-could-spawn-the-next-tesla/362112/ , http://www.gizmag.com/dual-carbon-fast-charging-battery/32121/ , http://www.extremetech.com/extreme/...e-breakthrough-weve-been-promised-for-so-long , http://revolution-green.com/ryden-dual-carbon-battery/ , http://powerjapanplus.com/about/news.html , http://powerjapanplus.com/battery/equation/ ,
[video=youtube;OJwZ9uEpJOo]https://www.youtube.com/watch?v=OJwZ9uEpJOo [/video]
And of course Ultacapacitors also remain an option:
[video=youtube;LYL6NyU1g3k]https://www.youtube.com/watch?v=LYL6NyU1g3k [/video]
This is a really good video that explains in a clear and simple way the suitability of Ultracapacitors in a transportation application. Ultracapacitors have the ability to be charged very quickly: the bus in this video can fully recharge its Ultracapacitors in just 5 minutes. This also means that the regenerative braking system on this bus -- in which the electric motors become generators when decelerating -- will work more efficiently, because they will not be trying to feed electricity to slow-to-charge batteries.
However, this bus also does have batteries as well!! The range of the bus on Ultracapacitors is only 3 miles, while its range on batteries is 15 miles. Which suggests that the TerraLiner, too, should probably have a similar combination of batteries and Ultracapacitors. When stationary and boondocking, ideally the TerraLiner's battery bank should keep all camper box living systems going for at least a day, if not longer, without charging. Whereas it would seem that a vehicle that only has Ultracapacitors could not do this; it would need to have its diesel engine running continuously, recharging the Ultracapacitors.
I may be wrong about this, so please feel free to correct me if I am. I am just responding to this video, which seems to lay out the technological options very clearly.
9. Oshkosh UltraCapacitors
It's worth repeating that Oshkosh diesel-electric vehicles use Ultracapacitors made by Maxwell technologies -- see http://www.dieselpowermag.com/features/1107dp_diesel_electric_hybrid_hemtt_oskosh_a3/#__federated=1 , http://www.oshkoshcorporation.com/pdfs/Oshkosh_ProPulse_drive_brochure.pdf , http://www.oshkoshcorporation.com/about/tech_innovations~propulse.html , http://www.dtic.mil/ndia/2007power/...snasrCopyofJointServicePowerOTC42407Final.pdf , http://www.forbes.com/2006/01/30/oshkoshtrucks-fuelcells-trucks-cz_atg_0131osk.html , https://www.tecategroup.com/white_papers/badnames/200904_WhitePaper_PowerModules.pdf , http://www.hybrid-vehicle.org/hybrid-truck-hemtt.html , http://www.maxwell.com , http://www.maxwell.com/products/ultracapacitors/ , http://www.maxwell.com/products/ , http://www.maxwell.com/solutions/transportation/auto , http://issuu.com/maxwelltechnologies/docs/auto_brochure/20?e=14613819/10386948 , http://issuu.com/maxwelltechnologies/docs/auto_brochure , http://www.maxwell.com/solutions/transportation/truck , http://www.maxwell.com/solutions/transportation/bus , and http://www.maxwell.com/about_us/press-releases .
Here is a list of reasons why Oshkosh chose Maxwell Ultracapacitors, instead of batteries -- see http://www.dieselpowermag.com/features/1107dp_diesel_electric_hybrid_hemtt_oskosh_a3/#__federated=1 :
Why Ultracapacitors Instead of Batteries?
Although Oshkosh selected ultracapacitors in this application, batteries or other storage devices could be swapped in if the situation called for it. A few advantages of ultracapacitors include:
1. They offer increased safety, since the capacitors can be brought down to 0 voltage for maintenance operations.
2. They work well in extreme temperatures ranging from -51 to 125 degrees.
3. Accelerated aging and cycling tests show they last the 25-year life of the vehicle.
4. Round trip efficiency is about 10 percent more than a comparable battery-electric hybrid, due to the ultracapacitor’s ability to recover braking energy.
The diesel engine is not mechanically connected to the wheels. Instead, it runs at an optimal rpm range and creates electrical power, which is delivered to the axle-mounted motors. When extra power is required to accelerate the vehicle, ultracapacitors kick in and deliver the burst needed. When it’s time to slow down, the motors in the axles double as generators and replenish the quick-charging capacitors.
A. 340kw generator (PURPLE)
B. 470hp diesel engine (GREEN)
C. 1.9mj ultracapacitors for energy storage (ORANGE)
D. 480 volts ac induction motors (one per axle, 4 total, BLUE)]
Here Oshkosh repeats one of the rationale's for Ultracapacitors also given in the video: "Round trip efficiency is about 10 percent more than a comparable battery-electric hybrid, due to the ultracapacitor’s ability to recover braking energy."
But I have the sneaking suspicion that boondocking in silence for a few days, without the diesel engine running, and just relying on solar panels to recharge the battery bank, is not part of the Oshkosh A3's design specification.....
:coffee: ... After all, the Oshkosh A3 is not a vehicle for living in; it is not a motorhome. And when it stops somewhere, all systems will shut down, so why would it need batteries? When electricity is needed, say, to power the lights of an airfield, then the diesel engine would be running.
Here is an interesting, more "skeptical" article about battery innovation: http://cleantechnica.com/2014/06/06/elon-musk-unimpressed-battery-breakthroughs/ .
For the volumetric and weight estimate for the battery bank, I have been calculating on the basis of currently available Lithium-Ion batteries. It's anyone's guess how much smaller or lighter Dual Carbon or Ultra-Capacitors might be, because they are not yet widespread automotive technology.
But again, it may turn out that the ideal solution is not either/or, but rather, both/and, as per the Shanghai bus in the video.
10. Diesel Engine KW relative to Electric Generator KW
egn, notice how the following image from the Oshkosh Propulse pdf would seem to undermine your 1 to 1.5 estimation of the KW power difference between the diesel engine versus the generator.
In this pdf's illustration, the Oshkosh A3's diesel engine is described as 450 HP or 335 KW, which is the same as the stated power output of its electric generator. So too, in Diesel Power Magazine the A3's diesel engine is stated as generating 470 HP, or 350 KW, while the electric generator produces 340 KW, or just 10 KW less -- see http://www.dieselpowermag.com/features/1107dp_diesel_electric_hybrid_hemtt_oskosh_a3/#__federated=1 . Does this strike you as a mistake? Or how would you explain what is going on here?
It's worth noting, of course, that the A3's 330 KW of electrical power production is roughly the same as the power needs of Blue Thunder. Which seems to suggest that the TerraLiner should have a 470 HP diesel engine driving the generator, at a minimum (or two equivalent diesel motors, driving two generators). As I mentioned before, a much smaller and lighter vehicle, Oshkosh's hybrid-electric L-ATV, has a 400 HP 6.6 L engine -- see posts #671 to #673, at http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page68 . All of this inclines me to think that campo's estimate of TerraLiner diesel engine size earlier in the thread -- in the 500 HP range -- is probably more nearly right.
11. Ideal or Sufficient TerraLiner Centerline Clearance
In closing, once again it would be really helpful if you could specify an "ideal" or "sufficient" centerline clearance, based on your experience with Blue Thunder. That would help me and my engineers tremendously....:) This is not something that even most automotive engineers could guess, unless they are automotive engineers who work specifically for Mercedes, designing Unimogs. What's really needed is real-world feedback from someone like you, egn, who has a MAN-KAT 6x6 that has done some interesting things in the field.
Although your MAN-KAT is truly off-road capable, and built like a tank, in many ways it comes closest to the TerraLiner as "model" or "precedent". Blue Thunder has a rigid, non-flexing frame, for instance, whereas most of the vehicles sold by UniCat or Actionmobil have frames that flex. Now I am not sure whether frame rigidity would help or hurt when it comes to the question of centerline clearance, and driving on deeply rutted roads. Only someone like you could answer this question. Whereas not even those who drive 6x6 UniCats could answer this question, because the frames on their vehicles are so different from the ultra-rigid tubular space frame projected for the TerraLiner.
Indeed, what is the center-line clearance of Blue Thunder? I know, it will vary depending on the tires used. But just a rough ballpark range: 50 cm to 60 cm?
All best wishes,
Biotect
thjakits
Hi Bio,
But on one side thjakits favors hub motors, while on the other.....
Actually - I do NOT favor Hub-motors [actually I was very much against hub-motors until I saw the Swiss/Dutch prototype racer thing, .....and that only had me at least THINK over hub-motors again......]
I think the best will be 3 central motors - 1 for each axle, as I mentioned already about 15000 pages further back..... !
HOWEVER, I would NOT throw out the hub-motors quite yet (or freeze the suspension or motor-question) - as far as I can see, none of us here has any medium or heavy Diesel-Electric Drive experience (...any Locomotive Engineers on here? Or DE-tug-boat captains?).
WE all seem to have a preferred idea for the suspension layout, but the e-drive options...? At least I got some surprises and education about what is available today and most likely will be available shortly (next 6 month to 4 years).
Same for batteries - gizmag shows SOMETHING new about batteries every week it seems....
Bio - you may get swayed one way or the other regarding all this - and it seems your initial configuration is no more anyway, but regarding the e-drive options, you REALLY should try to get in contact with some SPECIALISTS (...at least graduating student level, in the respective fields - e-drive, e-control, re-gen-charging, vehicle-batteries, super-capacitors, etc...).
These guys may have some seriously different ideas and reasons to recommend things one way or the other - WHETHER WE LIKE IT OR NOT!
At the end of it you need to find the most efficient formula for a EXPLORER/OVERLANDER - NOT for a Military-Truck, NOT for a Longhauler, NOT for a Motorhome that mainly is on shore-power.....
So far I did not get any indication, that anyone posting has any serious education/experience in operation/design/control of e-motors.
[If so - that person has some serious will-power to be able to NOT chime in!!]
Most of us seem to have some understanding about how/what/why, but that is NOT enough to hone in on a final decision - you need to find an expert in the field!! Or various for all of the fields involved - after all you won't just plug in a couple thousand AA-duracell rechargables and drive the thing on a Arduino or Rasberry board!!! :wings:
I for one would also be VERY interested to hear what the specialists have to comment about this project (engineering and driveline) and what THEY would use in their speciality fields!!
I am afraid/believe ENG is right, that for Terraliner you WILL need some kind of 2-speed trans, but I still would want to know from the specialists if there isn't a motor out there that can do "stand-still to 125 km/h" AND have the grunt low down to climb vertical (like a 80cm step - your tire will be flat against it and you will need some serious VERY slow speed power at the wheels....)
Your friendly engineering-DA,
thjakits:coffee:
biotect
Designer
Hi thjakits,
Your suggestion regarding contacting specialists is well-taken. Problem is, even specialists will disagree! All of this is not-yet-proven technology, after all. The problem isn't just that none of us has any concrete experience with E-motors in medium-to-large size overlanding trucks. The problem is more general: that very few people have such experience. Even Wrightspeed only has experience with E-motors used in urban garbage trucks.
Agreed, as you've said before any number of times, the critical issue will be designing a drivetrain that is optimal for the TerraLiner, and not for a military grade combat vehicle, or a rally truck, or a garbage truck. That point was absorbed many, many pages back....:) ...No need to keep repeating it. So agreed, even an outfit like Wrightspeed will probably not be able to give truly useful drive-train recommendations, for the TerraLiner specifically.
As near as I can tell, the only engineers on planet earth who have truly deep, extensive experience using E-motors in large trucks built for tough conditions, are the engineers who work for Oshkosh. I have tried contacting Oshkosh by email, but so far, no luck in getting a reply. Will probably have to telephone Oshkosh directly, and gradually figure out where the engineers are who work on diesel-electric vehicles.
With that said, however, it would still be great if participants were to post more concrete examples of hybrid solutions and independent suspensions built for tough environments. That alone might lead me to additional specialists with whom it would be truly worthwhile to discuss E-motors for a large overlanding truck. I found Oshkosh and PistenBully diesel-electric hybrid vehicles on my own, through Internet research. So it would be great if anyone else interested in doing a bit of additional hunting, would be willing to find and post other concrete examples of hybrid solutions for tough environments. Again, there is nothing quite as useful as concrete imagery, and links to websites and pdfs......
In the meantime, as I suggested before, the E-motor arrangement is not really critical, from a camper-box design point of view. It may seem absolutely critical to those who are really curious to know what the final drivetrain of the TerraLiner might be. But again, notice how the OEX-B, Nimbus, and Troy concept designs referenced earlier all leave such engineering issues deliberately vague. See post #969 at http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page97, and posts #972 to #994, at http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page98 , http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page99 , and http://www.expeditionportal.com/for...edition-RV-w-Rigid-Torsion-Free-Frame/page100 .
I don't want to leave things quite as vague as that. But even still, from a design point of view, the things that actually matter most are:
(1) The volumetric size and probable weight of the battery bank
(2) The volumetric size, power output, and probably weight of the diesel generator (or diesel generators, plural, as suggested by egn)
(3) The ideal or sufficient centerline clearance of the TerraLiner
These affect the design side of things considerably. And once again, it would be great to hear from egn on these issues.....:)
All best wishes,
Biotect
Haf-E
Just as a point of reference - The Tesla Model S with the performance option has a 310 kW 416 BHP induction motor.
The drivetrain is single speed with a 9.73 ratio differential. Top speed is 130 MPH / 201 km/h. The induction motor produces 600 nm of torque.
So - if the Terraliner was equipped with three of these motors (one per axle) and if the gear ratio was instead about 30:1 and the tires where 1.5 times taller (42 inch dia vs 28 inch dia) - the top speed would drop to about 60 MPH / 100 km/h. The torque at the wheel would end up being 600 nm * 30 * 3 / 1.5 = 36,000 nm.
I don't think well be able to find an suitable axle with a 30:1 ratio (even with a portal or hub reduction) - so some type of intermediate drivetrain would be required with the Tesla motor. Since something else would be required - it might as well have two speeds (as already mentioned) so that there would be a "crawl" gear and a "cruise" gear.
Since an intermediate gear box will be used between the axle/diff and the motor - we could then downsize the motor size since we don't really want/need 930 kW of motor power.
So if we had three "half sized" Tesla motors - and a crawl gear ratio of 4 to 1 - then the calcs would be:
Cruise: 300 nm * 30 * 3 / 1.5 = 18,000 nm
Crawl: 300 nm * 30 * 3 * 4 / 1.5 = 72,000 nm
While the torque numbers don't match that of the MAN KAT's - I think it would be enough for the intended use of the Terraliner. It depends on the weight of the rig and other factors - we'll have to look at that more...
thjakits
Hey Bio,
As a GOOD DA I have to keep repeating and anoying - can't just stop midway!!! :wings:
Agree - you will NOT find vehicle e-drive specialists and less so Explorer E-drive specialists!!
I DID not refer to a such individual anyway...
a) Even if you had access to one from any of the car makers, they would be able to say squat NOTHING about their expertise!
- ...that's why I suggested graduate students or near there.....they do all kinds of need stuff in labs and have the primary view on the near future!
b) When I say e-motor specialist, this is not limited to vehicle drives!! There are loads of other e-motor applications out there! LOADS!!
I sure you find any number of students/professors/etc.... that are up to speed and at the leading edge of e-motor engineering, that know all the ins&outs of what is do-able today and how to control it!!
c) ....even more so on battery technology.....!
Also - you keep mentioning COMPANIES as your specialist reference (Tak4, Oskosh, Wrightspeed, etc....) - they are only specialists on THEIR product!!
Consulting with them will not yield much innovation beyond what THEY specifically have to offer - ALL of them believe that they have the holy grail and will promote THEIR product and bash the competition.....
They are good indicators for different ways to do the same thing for mostly different applications, but as it looks - NONE fits the Terraliner EXACTLY (....unless you ask them - they will have all the proper reasons["excuses"] why THEIR product is the perfect one for the Terraliner - after all they want to SELL their product).
That is YOUR challange!! You need to find the proper way for the Terraliner - trying to copy from a industry that doesn not match your spec-profile will not help. Getting a view/idea does - but consulting THEM for Terraliner will not get you where you want to be.
We know what we want - so now get specialists in the applicable fields: E-Motors (in general!! here you also will get advice on dual-purpose motor/generators), Rechargable Batteries (in general!!), digital current/charge control (in general!!)....
- First you need a list of consumers on board! What do you want to run on electricity and how much will these consume?
- Then you need to decide how long you want to run on batteries alone at max rate - WITHOUT charging...
- Third need to find out ......see below
- Check if the this is near the capacity of what you found out above!!
- In any case - leave the battery type decision for absolute last - battery tech moves along at an incredible pace - don't freeze the system now!
You can get this by the thousands!!
Diesel-Electric power plants are out there EVERYWHERE!
You should be able to get weights off the spec-sheets or a email/call to the manufacturer - I suggest you concentrate to ti high rpm units, as they will be smaller/lighter - E.g. my 2.0Liter, 4 Cylinder, VW-Turbo Diesel will give me 200 hp all day long.These come in all sizes from 1.0 liter, 1.6, 1.8, 2.0, 2.5, 3.0, 5.0, ...and I think there is a 6.0 liter too (W12) - pick any power-level you want. I am sure most of them will also be used in "Industrial Mode" with different Emergency power plant producers. Probably need ot stay away from "fixed" Emergency Power Units (like in buildings) as these tend to be the heavy slow runners - weight doesn't matter here. Look for the trailer-mounted mobile units.
[VW was amentioned as this is what I drive right now and I KNOW they sell them as Industrial Diesels as well, but most engine manufacturers will sell their line under "Industrial Applications" as well].
The nice thing about the Serial Hybrid Layout is, that the IC-engine is reduced to general energy-PROVIDER, it doesn not need to proved also low-rpm/high-torque/start-up capability anymore....
It can run (...and be optimized!!) to basically 4 stages: start/warm-up - full power generation or minimum efficient power generation (see above - battery bank size) - cool-down/stop
Who knows - the e-motor guys may have something up their sleeves about that too!!
You wanted "out of the box" ideas - now it is for you to apply that too - DON'T get fixated on existing transport solutions - find info in other industries!!
As an idea - contact the Swiss/Dutch University team that came up with the Grimsel Racer and talk to them!!
They have non vested interests yet [I doubt they are stuck in their minds with their motor layout and battery-system they use....] - IF their motor is not perfect for Terraliner, they will say so and come up with a better solution based on HARD DATA. What is great though is that they are very enthusiastic about e-drive vehicles!!
Who knows - you might be able to get them (or another Uni....) started on a program tailored to Terraliner (or similar...).
Any chance for other specialities (vehicle-ENGINEERING, ELECTRICS, SOLAR, DIGITAL CONTROL) to a thesis on the Terraliner??!
[Your speciality is DESIGN, so I assume there would be space for others on the same project - as a bonus EVERYONE on the project could show that they are able to COMPROMISE and TEAM-WORK on the whole project to make it possible.....but still get their credientials for their chosen area].....
I guess you would have to do a bit of posting proposals to a load of Uni's......to assemble a proper team.
cheers,
thjakits:coffee:
biotect
Designer
Hi thjakits,
You are of course right, that if I want to get the engineering side of things – and E-motors specifically – specified in greater detail, then probably the best course of action would be to contact a few university departments that are at the forefront of current research. As you suggest, they will probably demonstrate the “flexibility” necessary to tailor a solution specifically suited to the TerraLiner.
And I am well aware of the possible advantages of this approach. In my second-to-last, very recent post I wrote, in sections 8 and 9, “Battery Bank Size, and Ultracapictors”, and “Oshkosh Ultracapacitors”, I wrote:
Hi egn....
But I have the sneaking suspicion that boondocking in silence for a few days, without the diesel engine running, and just relying on solar panels to recharge the battery bank, is not part of the Oshkosh A3's design specification..... :coffee: ... After all, the Oshkosh A3 is not a vehicle for living in; it is not a motorhome. And when it stops somewhere, all systems will shut down, so why would it need batteries? When electricity is needed, say, to power the lights of an airfield, then the diesel engine would be running.
So thjakits, it has already occurred to me that the Ultracapacitor system used by Oshkosh, may prove inadequate for a mobile apartment like the TerraLiner. What seems needed is perhaps a combination of Ultracapacitors (for efficient regenerative braking) with batteries (for longer term power storage). And a university department at the forefront of hybrid and E-motor research might be able to help me figure out such details in greater depth.
However, with that said, what you are describing is actually a design project that is quite a bit more ambitious than anything that I originally had in mind!! As I already wrote, for an MFA design project at an Art School (as opposed to a university engineering department), engineering details are not that critical. I feel tempted to repeat this statement, so that it might sink in.....:) ... But I will leave it to you to hopefully re-read this particular paragraph.
Again, as I suggested before, the E-motor arrangement is not really critical, from a camper-box design point of view. It may seem absolutely critical to those who are really curious to know what the final drivetrain of the TerraLiner might be. But again, notice how the OEX-B, Nimbus, and Troy concept designs referenced earlier all leave such engineering issues deliberately vague. See post #969 at http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page97, and posts #972 to #994, at http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page98 , http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page99 , and http://www.expeditionportal.com/for...edition-RV-w-Rigid-Torsion-Free-Frame/page100 . And these are all concept designs that would be perfectly acceptable in an Art School MFA context.
What you are describing, thjakits, is a much more ambitious project that I might engage in after I graduate. Assembling a team of the kind you describe would take time, and unfortunately the clock is ticking, and I have only a half a year left. And again, from the perspective of an MFA thesis at an Art School specifically, it is really not necessary. That might be a difficult pill to swallow, but there it is.
Indeed, even the extent to which I have tried to “ground” the TerraLiner’s design in real-world practical and engineering considerations, by creating this thread here on ExPo, was really not necessary. The OEX-B, Nimbus, and Troy are all perfectly adequate as concept designs, even though all three seem to be fairly unrealistic, from a serious overlanding point of view. What you are suggesting, instead, is the development of a concept vehicle that is much more highly specified than any of these; one that takes the design process to a very different level.
It’s not necessary for an Art School MFA, but it would of course be the necessary first step if one wanted to create a working prototype, as per the Walmart/Capstone/Great Dane concept truck. Interestingly, as the last of the following three videos make clear, Walmart originally wanted a much "liter" concept design: perhaps just a full-scale mock-up, but not something that actually works. But over the last 4 years Walmart changed the goalposts, and the design project turned into a much more ambitious effort to develop a fully working prototype:
In short, thjakits, you are proposing a change of the “goalposts” similar to Walmart. That’s fine, and it’s understandable why you should do so. But I am just an MFA student at an Art School. I am not Walmart with deep pockets.
All I wanted from this ExPo thread, from an engineering point of view, is some detailed “experiential” feedback from real overlanders who have large rigs: overlanders like campo, NeverEnough, graynomad, and egn. It is very interesting for me, for instance, that campo and NeverEnough strongly favor Independent Suspension, in part because they are a bit dissatisfied with the straight-axle/leaf-spring suspensions on their current rigs. And sure, it may be true that comfortable straight-axle is possible, via Air Suspension, or Kinetic Suspension. As such, it also very interesting for me that egn disagrees with campo and NeverEnough on this basic point. Wth just as much real-world experience, egn favors straight axle.
graynomad
: if you are reading this, it would also be interesting to know which you favor: IS, or straight axle.
Furthermore, I have greatly benefitted from additional sources of design inspiration such as the vehicles posted by Manigna, or the ideas floated by dwh. Recall that it was Maninga who has posted the lion’s share of images of more experimental, cutting-edge, Australian-built expedition motorhomes, such as Peter Thompson’s Mañana; and more recently, the Paradise Motorhomes expedition vehicle with full-length slide-outs.
In short, I appreciate your suggestion thjakits, and sure, I will contact a few university departments. But assembling a team of the kind you describe will probably have to wait until the summer. Furthermore, approaching such a team with a wealth of concept sketches, CAD files, and a few models already built, will provide a very clear sense of “design direction”, direction that such a team would need at the outset. This thread will also certainly help: simply reading this thread makes very clear what the design parameters and "mission profile" of the TerraLiner should be.
As already suggested, I am simply waiting to hear from egn – or others with extensive overlanding experience in big rigs – about what the ideal or sufficient Center-Line clearance should be, for a vehicle like the TerraLiner. And I would like to know how egn feels about Portals for a large vehicle; how egn’s Blue Thunder handles deeply rutted roads; what exactly egn was saying about the TerraLiners’ power requirement; and what egn was saying about Diesel Engine KW relative to Electric Generator KW – see post #1189 on the previous page at http://www.expeditionportal.com/for...edition-RV-w-Rigid-Torsion-Free-Frame/page119 .
I hope this post was not too deflationary, because yours is a good suggestion, thjakits, and I will take it up. But I will take it up only to a very limited extent, at this particular stage in the design process. Your much more ambitious project will have to wait until late summer, or the fall. My engineering friends mainly have backgrounds in structural engineering, and they certainly don't have much background in E-motors or hybrid vehicle drive trains. But at present their expertise is enough, and is greatly appreciated. Their particular expertise suits my purposes perfectly, because I have been mainly concerned with the camper box and overall chassis frame design.
So what I am looking for, right now, is a few answers to the above questions, from overlanders who have plenty of experience using big rigs on deeply rutted roads. Right now, I am just looking for a few answers that will help me with camper box and overall chassis frame design.
I hope that is clear enough.....:)
All best wishes,
Biotect
biotect
Designer
Pre-emptive disclaimer: thjakits, before you jump all over these posts observing (yet again) that military trucks and rally vehicles have specification conditions different from the TerraLiner, please do try to remember that I already know this! Your point sank in ages ago. I am merely posting this material because it is of some interest; I have it easily available to post, because I already wrote up much of it; and because looking at maps and videos of the Baja 1000 is fun.
The Oshkosh serial hybrid L-ATV is also the only example that I know of, available on the web, of a serial-hybrid vehicle larger than an SUV, that has been tested in rally conditions. So that alone does make it interesting, even if it is not 100 % relevant to the TerraLiner. So please, don't bother posting again about this basic, very elementary point, which is not that hard to understand.....:)
1. A Few More Thoughts about Oshkosh Diesel-Electric Hybrids, and the Baja 1000
While the posts about Oshkosh's TAK-4 suspension system are still relatively "fresh", only a few pages back (beginning with post #1106 on page 111 -- see http://www.expeditionportal.com/for...edition-RV-w-Rigid-Torsion-Free-Frame/page111 ), thought I would post a bit more material that I wrote up a while ago, about Oshkosh Diesel-Electric Hybrid technology, and the Baja 1000.
Oshkosh is a widely diversified corporation, with a range of product offerings both military and civilian – see http://investor.oshkoshcorporation....ng/86987-Oshkosh_At_A_Glance__v001_y7bdg6.pdf . Perhaps for this reason, Oshkosh seems to be a very "proactive" sort of corporation, willing to develop new technologies at its own expense, independent of government contracts and handouts. Oshkosh's development of TAK-4 independent suspension, as well as its development of diesel-electric, off-road capable hybrid technology, seem to be two examples of this kind of proactive innovation.
As previously mentioned, the Oshkosh hybrid diesel-electric HEMTT A3 is “technology available now” – see http://oshkoshdefense.com/vehicles/hemtt-a3-diesel-electric/ , http://oshkoshdefense.com/wp-content/uploads/2013/08/HEMTT_A3_SS_6-13-11.pdf , http://defense-update.com/features/du-3-05/feature-HED-trucks.htm , http://www.hybrid-vehicle.org/hybrid-truck-hemtt.html , http://oshkoshdefense.com/components/propulse/ , http://www.oshkoshcorporation.com/pdfs/Oshkosh_ProPulse_drive_brochure.pdf , and http://oshkoshdefense.com/wp-content/uploads/2013/08/ProPulse_SS_6-13-11.pdf ; and see post # 334, at http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page34 , or post #503 at http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page51 .
And the HEMTT A3 is a serial hybrid solution:
Again, it's worth noting that HEMTT A3's engine is a 470 HP diesel, JP-8 compatible, and that its generator produces 340 KW, which power four 480VAC electric-induction motors, one per axle (the A3 HEMTT is an 8x8). At first this struck me as an engine and generator much bigger than would be needed to drive a 3-axle, 6x6 expedition motorhome. The HEMTT A3 seems to be marketed as a kind of “mobile, self-propelled generator”, providing 100 KW of exportable power for remote applications, for instance, lighting up an improvised aircraft runway:
CONTINUED IN NEXT POST
biotect
Designer
CONTINUED FROM PREVIOUS POST
Session14presnasrCopyofJointServicePowerOTC42407Final.jpg Session14presnasrCopyofJointServicePowerOTC42407Final2.jpg Session14presnasrCopyofJointServicePowerOTC42407Final3.jpg
Session14presnasrCopyofJointServicePowerOTC42407Final4.jpg Session14presnasrCopyofJointServicePowerOTC42407Final5.jpg HEMTT_A3_SS_6-13-116.jpg
So the size of HEMTT A3’s engine and the size of its generator are perhaps geared to that intended application. Perhaps they are not strictly necessary to power the vehicle itself?
But then egn wrote that Blue Thunder's overall power requirement for a 3 % incline is 300 KW, which is very near the power output of the Oshkosh HEMMT A3.
biotect
Designer
2. Diesel Electric Serial Hybrid Technology, as Implemented in the Oshkosh MTVR
There's also the question about how Oshkosh has applied Propulse to its medium-weight MTVR line of trucks. The TerraLiner should be classified as a medium-weight vehicle, and not as a heavy-weight vehicle like the HEMTT, or MAN-KAT 8x8s -- see http://oshkoshdefense.com/products/heavy-tactical-vehicles/ .*
Although Oshkosh does not explicitly advertise the availability of Propulse hybrid technology for its MTVR line of trucks, it has in fact been tested in these medium-weight trucks as well – see http://oshkoshdefense.com/vehicles/mtvr/ , http://oshkoshdefense.com/wp-content/uploads/2013/08/MTVR_Bro_Single_6-13-11.pdf , http://oshkoshdefense.com/components/propulse/ , http://oshkoshdefense.com/wp-content/uploads/2013/08/ProPulse_SS_6-13-11.pdf , http://www.dtic.mil/ndia/2007power/...snasrCopyofJointServicePowerOTC42407Final.pdf , http://www.dtic.mil/ndia/2009power/may6Nader.pdf , and http://www.dtic.mil/ndia/2011power/Session16_12834Mimnagh.pdf :
biotect
Designer
biotect
Designer
Session14presnasrCopyofJointServicePowerOTC42407Final17.jpg Session14presnasrCopyofJointServicePowerOTC42407Final18.jpg Session14presnasrCopyofJointServicePowerOTC42407Final19.jpg
Session14presnasrCopyofJointServicePowerOTC42407Final20.jpg Session14presnasrCopyofJointServicePowerOTC42407Final21.jpg Session14presnasrCopyofJointServicePowerOTC42407Final22.jpg
And for further discussion and links, again see post # 334, at http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page34 , or post #503 at http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page51 .
3. Other Military Hybrid Initiatives
Going back in time a bit, in 2005 Defense-Update created very general survey of Hybrid technology in military applications. Yes, it's now a bit dated, but it provides a good introduction – see http://defense-update.com/features/du-3-05/feature-HED.htm , http://defense-update.com/features/du-3-05/feature-HED-about.htm , http://defense-update.com/features/du-3-05/feature-HED-humvee.htm , http://defense-update.com/features/du-3-05/feature-HED-trucks.htm , http://defense-update.com/features/du-3-05/feature-HED-afv.htm , and http://defense-update.com/features/du-3-05/feature-HED-power.htm .
For a 2009 review of testing of the Army's AHED (“Advanced Hybrid Electric Drive”) 8x8 hybrid prototype, as well as the RST-V ("Shadow Reconnaissance, Surveillance, Targeting Vehicle"; more later in the thread), and the AGMV (“Advanced Ground Mobility Vehicle”, also more later in the thread), see http://ecst.ecsdl.org/content/16/16/1.full.pdf or http://ma.ecsdl.org/content/MA2008-02/6/551.full.pdf+html . Also see http://defense-update.com/products/a/AHED.htm and http://www.theengineer.co.uk/in-depth/powering-ahed/291227.article .
But for me personally, far more interesting are military applications of hybrid technology that have occurred since Lithium-Ion batteries became widespread and significantly cheaper. Lots of smaller, 4x4 hybrid military prototype vehicles have been developed in recent years, many of them in anticipation of the U.S. military's huge JLTV (“Joint Light Tactical Vehicle”) program. See for instance http://defense-update.com/features/november_07/mdm07_hed.htm#more . And almost always they are serial hybrid.
ddsafadsf
biotect
Designer
4. The Oshkosh L-ATV: developed for the JLTV program
Again, the most important and advanced of these military prototypes would appear to be the serial-hybrid L-ATV, developed by Oshkosh in response to the JLTV procurement program.
First, some images from Oshkosh's JLTV brochure -- see http://oshkoshdefense.com/wp-content/uploads/2014/09/16589_JLTV_8pgBrch_LowRes.pdf :
16589_JLTV_8pgBrch_LowRes.jpg 16589_JLTV_8pgBrch_LowRes2.jpg 16589_JLTV_8pgBrch_LowRes3.jpg
16589_JLTV_8pgBrch_LowRes4.jpg 16589_JLTV_8pgBrch_LowRes5.jpg 16589_JLTV_8pgBrch_LowRes6.jpg16589_JLTV_8pgBrch_LowRes7.jpg 16589_JLTV_8pgBrch_LowRes8.jpg
oskarf150
