Ambulance Conversion - New Modifications.
patoz
It may sound funny but I didn't tried yet the shore power, and especially now I have no idea how it will work.
I just can't find a 15a to 20a extension cord and I don't want to replace the connector to a 30a one.
Will it be simpler with the Sure Power 1202 ?
Thanks, good night.
Any 14 gage standard extension will carry 15A and any 12 gage cord will carry 20 amps. Use a 12 gage cord if at all possible!
No, the Sure Power 1202 is just a stock photo of what an electronic battery isolator looks like. This is what I was saying not to use.
Just FYI, I will be outside working on my house all day long, so I may not be available until tonight.
emtmark
Austere Medical Provider
Vanner and fleetpower are great inverters. A lot of energy is wasted when you use them however. There should be a switch for turning the inverter on and off. Judicious use will greatly extend battery life. Our rigs will die in about 16 hours if the inverter is on and rig off. Only thing we charge is IV pump. Which is hardly anything
patoz
Thanks, good night.
I think I misunderstood you when I answered this the first time.
I'm guessing you have a 20A recessed male receptacle mounted on the driver's side of of the vehicle, and you want to connect it into a standard 15A home type outlet. The easiest way is to use an adapter and standard 12 gage extension cord.
http://www.amazon.com/Conntek-1F515...ts=p_n_feature_keywords_browse-bin:2798281011
Be sure to check your blade pattern on your vehicle receptacle, because there is more than one kind, and this is just a temporary solution unless the vehicle is stored inside out of the weather.
VanIsle_Greg
Thanks, that gives me a good estimate.
Can you tell me which fridge you use or recommend?
Our trailer had a Dometic RV style 3 way fridge. It was small, and worked well and having LPG/12v/120/220 was awesome.
Basically this unit here.
http://www.americanrvcompany.com/Do...-3-Way-Compact-Refrigerator-Trailer-RV-Camper
What I have now for my offroad trailer is a chest style Dometic CF-35. It is small, and pricey, but an EXCELLENT fridge. It is similar to the ARB and the Engel fridges of the same or similar design. There are a number of manufacturers that use the same very efficient swing motor (Dan Foss) which is superb and lasts a very long time in operation.
http://www.americanrvcompany.com/Do...-Fridge-Freezer-AC110-CF-35-Trailer-Camper-RV
Dometic makes a lot of different sizes of fridge based on your needs. So does ARB, Whynter, Truck Fridge, Engel and others.
http://www.americanrvcompany.com/Dometic-Portable-Refrigerators_c_1671.html
http://store.arbusa.com/fridges-c11.aspx
http://www.engelcoolers.com/acdc
I know they seem expensive, but they use little electricity on low settings once cold and on 12v compared to others.
yzeevy
I bought me one 12 gage 6' 20A cord, male and female, and a 15A connector.
Before started cutting, I tried to plug in and guess what, the flat pins are opposite.
I can see that both sides can be either way.
Its possible to reset them or I need a new wall outlet?
yzeevy
I plan for the next 2-3 years to basically live in the AMBO so I need a bigger one and with freezer.
My daily BBQs are over so I make most of my food.
I lean toward the potable one too.
emtmark
Chest style fridge freezers offer greater economy that the stand ups. Do a little searching around you can do little mods onto get your freezer section like you desire
patoz
In your previous post you stated you are planning on living in the Ambo for a couple of years, so here are a few questions...
1. Does it have any type of 120VAC electrical panel, and if so what is the rating of the main breaker?
2. Are you planning on staying in pay campgrounds a lot?
3. Do you need to be able to plug it in at your residence or other places that just have standard 120VAC outlets?
4. Can you post a detailed photo of the recessed inlet mounted on the Ambo, with the cover open so I can see the actual male inlet plug configuration? If you can read any of the nomenclature printed on the male inlet plug itself, include it also.
Once I know all of this, I'll be able to make a better recommendation.
yzeevy
Since you are the AMBO veteran:
I found this air connector with his sensor relay detached probably broken off.
http://www.kussmaul.com/091-28.html
I understand the purpose of the jig but I don't see myself using it.
I thought this is part of the vacuum system, which I disassembled, so I cut the air line just to find out
that this activated the AIR DUMP.
I blocked the hose temporary but the power is still connected to the relay and
I wonder what would be the best way to handle this.
patoz
That is an 'Automatic Air Disconnect' system, and has nothing to do with the vacuum system.
It's usually found on vehicles with onboard air systems, especially fire apparatus, that have air brakes, air ride and air bag systems, etc. When the vehicle is parked for a long period of time, the air pressure tends to leak down and can prevent the vehicle from moving in the case of air brakes, until the onboard compressor can build up enough pressure to cause the brakes to release, causing a delay in response time.
The solution is to supply the vehicle with external air pressure via that connector, just like using 'Shore Power' for the electrical system. Since drivers get in a hurry and forget to unplug this stuff sometimes, manufacturers made it automatic when the ignition is activated and the vehicle started. A 12VDC current is passed to the solenoid on the Air Eject device, causing it to release the air hose fitting and eject itself, propelled by the static air pressure in the line.
If you don't want to use it, cap off the line very tightly and just disconnect and insulate the wires.
yzeevy
You cut the air dump?! So your in a permanent squat?
I blocked the hose temporary and I can drive it, but I want to know if I should buy a new air connector
or I can disconnect it.
BTW, are the RV fridges must be installed into the recesses or can they be like a
home fridge, of course tied and secured?
patoz
Why did you cut it loose in the first place? Was there something wrong with it?
yzeevy
I opened the cover and I saw the broken solenoid and I have "decided" its part of the vacuum system.
When I saw the back lowering down I understood my mistake.
I screwed in a long wider screw and it seems to be OK but I think there is a small leak.
yzeevy
1. Nothing like in RVs
2. To be realistic, I probably will have to stay in campgrounds most of the time.
3. At my current residence I have no access to 120VAC, I use the generator.
4. But of course:
I probably will keep 2-3 adaptors, right now I want to try out the shore line.
