Ambulance Conversion - New Modifications.
yzeevy
I purchased these and was happy with them. Easy to use and lock in place. amzn.com/B0006LBUFC
The question is for what you use them.
I want them as a support for the bed and since I cut the bed in two actually I need four of them.
I might have a problem to have a flat bed if they are not 90 degree.
I think I need an adjustable pole / stick
yzeevy
Basically yes, but I need to be able to put them away in the morning.
I'll take tomorrow new picks to clarify.
This would be the best but its too long and made in Spain.
http://irgslide.com/fd55-top-mount-table-slide/f55d-top-mount-table-slide.html
Turns out that the "wall" is not level either so it makes no much difference if the bracket is not 90 degree.
I found a way to compensate by installing these things and adjust them as needed . . .
I also have decided to cut the bed in almost in the center.
This way, when I lift the base I have a place to put the bedding.
Finished . . .
