Lets see some full size pictures...
noJeepshere
New pics of it actually off-road after the axle swap, got most of the bugs sorted and it's good for some fun trips this summer.
sent from a slablet
WrenchMonkey
Mechanical Animal
Sweet rig. A 7.3 Excursion would be about the only thing that would get me out of my Suburbans.
Nope, no way, not me. I had a 7.3 F250, and my 8.1 Burb will flat walk away from it. All the torque, double the horsepower, 1000lbs lighter, for half the price.
IdaSHO
IDACAMPER
Yep, just race to the next fuel station, as the diesel passes it up without the need to stop.
WrenchMonkey
Mechanical Animal
Yep, pass anything but a Shell!
But my 7.3 only got 13-14, empty or towing. The Burb does ten empty and 7 towing.
So worst case, towing, 100 miles is 7 gallons of diesel, 14 gallons of gas. But diesel is still 50% higher. At $2.25, that's $16 for diesel. $21 for gas at $1.50.
It'd take 180,000 miles to recoup the nine grand I saved on the Burb.
IdaSHO
IDACAMPER
You should really get out more.
Even checking your local Cincinnati prices, Diesel is 1.95 and reg is 1.59
Those numbers are from gasbuddy.com
So less than 20% difference for those with a calculator
So that's $13.65 for Diesel, and $22.26 for gas
A difference of $8.61 for every 100 miles using your own mpg numbers.
To each his own, but to claim a 8.1 is BETTER than a 7.3 PSD because of the power it has it retarded.
Especially when it gets HALF the fuel mileage regardless of conditions.
And seeing that you think the 8.1 has
i feel inclined to correct you.
2002 8.1L suburban
330 hp @ 4200 RPM
450 lb.-ft. @ 3200 RPM
A 2002 7.3L Excursion
275 hp @ 2800 RPM
525 @ 1600 RPM
So in fact, it does NOT have all the torque of a similar vintage 7.3, nor does it have double the hp.
Looking at it another way... you get HALF the fuel mileage having just 17% more hp and 15% less torque.
His math is off on the 100 miles also. He said he gets 7mpg towing and then goes on to say if he tows a hundred miles that 7 gallons wrong!!!! that would be 7 gallons just driving that 100 miles where as towing that would be 100 miles at 7 mpg 14.28 gallons. twice what he quoted.
2002 8.1L suburban
330 hp @ 4200 RPM
275 hp @ 2800 RPM
525 @ 1600 RPM
WrenchMonkey
Mechanical Animal
I didn't mean to restart the gas v diesel peepee match, sorry.
Yes, I exaggerated a bit. My 2000 F250 was 235/500, and I always saw 340/450 for the 8.1. So 90% of the torque, almost 50% more power. Either way, still more than enough to do what I need.
$0.08 per mile is still 112,000 miles to recoup the $9k difference, in a vehicle I drive a couple thousand miles a year.
My point wasn't that the 8.1 was better than the 7.3. But for my use, it's just about as good. And with the sudden demand of the diesel fad driving up prices on the limited supply of Ex's to ridiculous levels, my Burb was a MUCH better buy for me.
WrenchMonkey
Mechanical Animal
...100 miles is 7 gallons of diesel, 14 gallons of gas. But diesel is still 50% higher. At $2.25, that's $16 for diesel. $21 for gas at $1.50...
V45W_Proto2.5
