JJ72Roofer
Green is for the money and gold is for the honeys.
Those gold wheels would look right if your van was Subaru blue...
wait a minute, are going to rally cross V4?
Wow... and I thought Hutchinson's were expensive.
A top quality product is never expensive. You buy it once, from a company with an excellent reputation, solid warranty and good customer service. The product should therefore last a lifetime. If you want $99 cast Chinese wheels, knock yourself out. There is no comparison to a motorsport grade or military grade forged wheel.
If you want to see a high dollar wheel, look at HRE, easily $3000 - $5000 for a set of four.
Chris, will there be matching green shag carpet and some gold accents inside the van to go along?![]()
B190 is here! Ready to transform this marshmallow. These rigs are the most dramatic difference before/after.
The 6" has a better turning radius because we can run a longer pitman arm. For our 4" leaf kit we keep the stock arm due to interferance between the arm and the D side leaf spring at full bump/lock left. Years ago I compared a stock van and a 6" with RSC upgrade. Full lock left, dove them in a complete circle and measured the difference. 1' less with the 6" RSC van. The coil conversion has a better turning radius than both but I haven't measured.
Run 33's instead of 35's and you're almost to your goal. There are also a few springs you can try that will sit lower but you'll lose bump travel.
