FOUND Vans For Sale!
kccourtney
https://santafe.craigslist.org/cto/5925653523.html
1985 VW Vanagon Westfalia (Pop Top), Redone, Runs & Drives Great - $11500 (Lake Havasu City, AZ
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Paint job is about the ugliest possible combination of color's imaginable, but the van looks immaculate if you're into Vanagons.
Dang, that thing's pretty fresh. I don't even mind the paint scheme....could have done worse.
KeyserSoSay
Yeah, I should have kept my opinions about the paint to myself ( I don't want to offend other's sensibilities), but the van was just too showroom ready not to post up here on the EP. Seems like a great price for that level of resto.
Jsweezy's rig is much more my speed, but I've got one van project too many as it is :drool:.
Jsweezy
Thanks!
Timjim
Nice looking E350 4x4
https://portland.craigslist.org/wsc/cto/5951841734.html
"2008 Ford E350 4wd
V10 6.8L
5 speed torque shift tranny
Rear Ford Limited slip differential
Ujoint/MG conversion
2013 F250 Front axle
NV271 Transfercase
New BFG KO2 285/70/17
Fox shocks front and rear
Passenger seat swivels
Tow package
K&N Intake system
Sound deadening/roof insulation
Rear Backup Sensors
Aftermarket stereo/speakers
REAR AC UNIT
3/4" Rubber mats for flooring
Pop out windows on side and rear
CRL T-slider Windows
I am asking 25,000 OBO
Clean title in hand ready to go.
van"
I am hearing that the seller might sweeten the deal by throwing in a real live Bengal Tiger.
Guri
2001 Ford Quigley 4x4 E-250 - $5999 (La Verne)
http://inlandempire.craigslist.org/cto/5965387238.html
2006 ford E-150 for sale.
Selling my ford van.
2006 ford e-150, 4.6L, ~90k miles, less than 1000 miles on the rebuilt engine
I've done just about everything to this van in the last 1yr......
12/2016 the van got
-rebuilt long block with new timing chains/tensioners/guide rails, new pistons/rings, new rod and main bearings, all new gaskets (duh)
-radiator
-water pump
-thermostat
-belt tensioner
-belt
-idler pulley
-all cooling system hoses
-spark plugs
-cam sensor
-crank sensor
-purge valve hose from valve to intake
-starter rebuilt (by a local generator shop, not a auto parts store junk)
-alternator rebuilt(same as above)
-A/C system service
-transmission service, transmission front and rear seals (had it out)
-driveshaft balace/new u joints
7/2016 van got
-weldtec 4" suspense system consisting of
-front coils
-bent I beams
-fox 2.0's all 4 corners
-fox steering damper kit
-re arched rear springs, with 2 added leafs
-differential rebuild
-4.10 gears
-track loc limited slip
-new bearings/seals
started the "camper conversion" process.
its got a 3/4" plywood floor, with solid sheet of vinyl flooring bonded to it
the rear/side doors are stuffed with ROXUL, and have adrian steel poly liner door panels installed, the door panels have a layer of reflectix on the inside.
driver side wall has the adrian steel poly liner installed, all the reachable cavities stuffed with roxul and a layer of reflectix glued to the poly liner wall.
passenger side rear wall has been stuffed with ROXUL, and will be getting the poly liner wall installed this week with reflectix.
$11,000
full story here:
http://www.expeditionportal.com/forum/threads/151472-Simple-kind-of-van-a-2006-e150-build-thread
gp01
