seanpistol's 01 Tundra
toyotech
Glad you are keeping it. You spend way to much time and money on it not to even get to use it. Looking forward to more pictures and flex photos !!
Blackdawg
Dr. Frankenstein
Good to hear!
Maybe when it goes for sale a 3rd time i can afford it :p
jk..i dont' need 3 built toyotas.
Glad you can keep on wheeling.
rickashay
Good decision... again ;) Glad its staying and you were still able to get into a diesel.
Now I'll get a time extension to get down south and wheel with you and the Tundy one of these days. I was drooling over all the LT front/no fiberglass photos when you decided to post it. Love the wide stance.
toyotech
Hey Sean. We plan on going to Moab again for the taco rock therapy event. I think it's dubbed roctober. It's in October if you wanna go again.
seanpistol
Made time to finally cycle my suspension and make sure everything is clearing as it should.
Making contact about 1/4" before hitting the bumpstop.
To be removed.
Slight rub on the front bumper- need to trim it again, but I'd like to make a new crossmember and move it back a few inches first. This is full bump.
Full bump and lock at the firewall tub.
Full bump and lock post trim, it stuffs better than this photo leads you to believe.
Now that the rear is an inch wider I opened it up another 3/4"-1" on top. Don't have a photo of tires stuffing post trim.
Separation between the inner fender liner and the outer fender. A huge PITA.
Tried Monstaliner out in case I want to do my whole truck with it.
The uniball contacts the top of the fender well at full bump. If I were ever ambitious enough to run 37s with IFS I would do a 1" body lift. Without it, you'd have to tub the top of the fender well, re-tub the firewall all the way back to the door hinge, and you really can't trim the fenders any more.
seanpistol
I have the stock leaf pack with 3 extra leafs. I need to add at least one more. Not trying to spend the money on a custom leaf pack any time soon.
Blackdawg
Dr. Frankenstein
Check out Raptor liner. You can make it lay down like paint if you add paint thinner and shoot through a paint gun. Would look WAY better than Monsterline. Plus you can tint Raptor liner to any color you want.
DanoWall
