What did you do to your Mitsubishi today?
bikerjosh
casue the temp is over 100, might as well get under the gen2.5 for maint
Time to prep the Montero for upcoming trip to desert. New fluids, frt & rear diff, TC, engine, and transmission fluid swap (still waiting on arrival).
uQAhw
HartPA
Took it on an adventure, ended up getting stuck in a hole that was deeper and soupier than I'd expected.
Its a monument to bad decisions.
SD_Montero
Building a sleeping platform/simple storage system. Any ideas on how to make it fold put over the middle seats and be sturdy and supported ?
Sent from my HTC One M9 using Tapatalk
JAVYPRO
Had to change the valve cover gaskets on the 1990 LWB. Getting the aftermarket rubber gaskets to stay put in the valve cover channel is a royal pain in the :shakin:, I had to put some gasket shellac and it helped some.
The things I hate the most when working on my 1990 LWB: valve cover gasket, removing/installing the radiator fan 4 nuts.
Tried but couldn't post pics
Javy
SD_Montero
I fixed my sunroof, though putting it like that makes it sound like I did a lot more work than I actually did. I took an old toothbrush, and cleaned all the grit and gunk out of the threaded dealies that move the glass, then lubed them up with white lithium grease. The sunroof moves smooth as silk, now.
Do have any pics of what you did, mine is in need of it bad and I'm not sure what to clean. I've tried cleaning and lubing the rails but it's still not great. Did you clean with it open or closed? Thanks.
bikerjosh
towed it back from Bishop to Walnut Creek after it died above 10k feet w/electrical issues on the North side of Coyote Flat. Can now say I have coasted my Montero down crazy steep (well, it seemed that way) trails with no power brakes or steering. Pucker Power!
Time to dig into FSM.
Died, no warning. Crank, no start. All fuses and relays check out. No 'check engine' light when turning key to on position. Swapped ecu out with another Montero on the trail, and ecu checked out. OBD2 port won't link to rest of the car. Had an Ultra-gauge plugged in but after car died it wouldn't get past boot screen. Tried two different code readers and both responded with 'link error'
First time Montero crapped out on me. :ar15: Back on the trail soon, mark my words. :smiley_drive:
SONICMASD
Wow, that's no fun. I'm really interested to hear what this problem turns out be, keep us posted and good luck!
Salonika
Monterror Pilot
Repaired drivers side rear door lock actuator. I discovered that a hair dryer releases the dust barrier adhesive like magic, don't cut the plastic! Reinstall the same way by heating and working it back into position.
evomaki
bikerjosh,
What was the issue with your Monty? Just re-noticed this thread and I don't believe I've seen you post an outcome. Maybe you have. Anyway, I hope you got it up and running easily enough.
Toasty
Check the control module on the top of the engine, those can come unplugged and shut the whole thing down.
