ttengineer
What shocks do you plan on running?
For reference, on my Tacoma I ran a set of Icons initially before ponying up for a set of Kings. Go Kings. 300%. The digressively valved Icons were definitely more street friendly in terms of managing body roll, but they tended to be harsh over small bumps and blow through their travel over large bumps. The Kings had a brief zone where they would allow body roll before firming up, but were plush over small bumps, dropped into and sucked up bigger bumps, but were way, WAY more comfy on dirt/washboard type roads. Spend the extra 600 and get the compression adjusters, they actually do make a difference and you'll be thankful you did.
When you order your Kings just make sure you order the right stoke and shaft length.
someone needs to upgrade your Motorola Razer to like an iPhone 3 or something
I wish someone made replacement coils for the Ram that work with the AEV lift.
It's turning into a much harder find than I thought initially.
When I did my suspension I ordered a carli backcountry, mainly for a better ride and handeling, I wanted to save some cash over the pin top and thought I’d be happy with the Fox 2.0 shocks... now I’m wanting to get a set of Kings, which ride awesome and make your truck Handel like it’s on rails.
Do it once, get the Kings
I absolutely agree. I would not be apposed to having custom coils built to Thuren specs but with the lower profile of the stock coil for mounting purposes... Now, to somehow acquire such said specifications.... lololol
In a way it sucks, the only parts I really need from the AEV kit are a couple of brackets in the front part of the kit. Everything else needs to be upgraded or changed to support what I want the truck to do and the ride quality I want (not a mall crawler). It would be great if thuren or carli just built a kit that moved the axle forward to accommodate 40s.
Fab Four sells their flares that they say clear 40s, however, their kit requires you to cut a lot more out of the rocker panel than the AEV kit does. I read thru the fab four instructions, OMGosh, they cut another 2 inches out of the rocker panel and get fairly close to the lower door hinge (no thanks)....
