Expedition One Rear Bumper
ttengineer
ARB just took the bumper they’ve been making for 20+ years and changed to mounts to fit a Ram. It’s wildly unimpressive.
BUT, it works, is readily available, and offers a skid plate for the ‘13+ trucks.
chet6.7
I am having a local shop install the bumper,it would have been completely installed today except for some difficulties.We were looking for the bearing races,they were already installed,they were rough as sandpaper,I had to order new races,they won't be in until Tue.
I ripped this picture from marshal's thread to describe another problem.When the silver colored plate next to the hinge was being installed the installer thought the screws were a little to short,not going all the way through the nylocks,a trip to the hardware store solved that.
I was looking around under the truck at the stock license plate lights,it looked like they would reach the holes in the bumper if I cut a couple of factory zip ties and rerouted the wires.They reach,it's too bad Expedition One didn't design the holes in their bumper to accept the stock lights.I have them Gorilla taped in place as a test,until I figure out the best way to illuminate the bumper,I can drive it if I need to.
The next problem is the holes Expedition One cut in the bumper for the backup sensors.Three are on the same axis,the fourth hole, on the far right passenger side, is cut differently,it's tilted a few degrees off from the other three.I suspect it will effect the detection angle of the backup sensor.(n)
The next problem is mine,I don't know how to get the backup sensors out of the stock bumper,so I asking for some tips in getting them out in one piece.
chet6.7
Charge back started. Not that it matters but no response to my last two email.
If I had a do over I would have bailed on this thing.I started calling them because they were not answering my emails,I switched back to email when I realized I was getting BS'ed about the delivery date and I wanted a paper trail. Good luck on getting it resolved favorably.
I've been following your thread and comments, as soon as they started doing what you had been describing I punched out. I'm certain my CC is going to pull the funds back. I knew going in this was a possibility so I wasn't going to let this drag out long enough that I no long had consumer protection. I'm already working on another front bumper.
You're bumper looks great, once you work out the bugs I'm sure you'll have a good setup. It's too bad Expedition One has so many issues.
chet6.7
The back up sensor hole on the right is clocked differently than the other three sensor holes.
You can also see how fragile the powder coating is.
chet6.7
I have to use a pry bar to open the passenger side latch,it worked OK a few times,now I need a pry bar and it is more difficult to close than the other side as well. The powder coating shows were the pry bar is being inserted.
chet6.7
It seems with a little more thought at the design stage the stock rear tailights could have been used.You can see the stock bulb.
chet6.7
The holes for those two bolts had to re-drilled,and a weld on the bottom below the bolts had to be cleaned up so the wing could close.DSCN0329.JPG
Tebirds55
I've been following this thread for awhile now. I hate to read about all the trouble you have had with this company, but appreciate the enlightening info you have given us.
I have been thinking about getting new bumpers for my super duty. Even though I do like the bumper, but I will not buy one from them! Hopefully not all vendors are not this bad.
Good luck
DFWSFO
