Ram 2500 XL for overland / expedition trips
Ravenmad
Why are you going with different tires?
X2
A couple of reasons, 1. the conti's are down to 60% with a little less than 13K on them. I really do like them but the tread life is a bit disappointing. I have abused the tires though, with no sign of damage but the tread life is abysmal. I may try a set of goodyears also, we will see. 2. I want a bigger tire, I have room, the new front axle assembly will deff. not break... Heck, if they made a 43 or a 44 that I could get to fit I would probably entertain it. 3. The tires were the right price, I am coordinating the logistics and coms for an Ultra 4 team at KOH, Maxxis is a sponsor and the deal was extended to me.
silvrzuki77
explorer
Bummer to hear about the tread life on those!
Hopefully I will be making a trip out to KOH as well this year.
Ravenmad
@Ravenmad, was the cutting/prep/install for the AEV fender/flares as bad as they say it is?
I got the same question. I was just thinking about dropping the truck off at a body shop if I were to go that route, which I might, these 37’s are just too small now.
Well, I will say this... I can be picky, so I spent about 20 hours installing the front and rear flares. It is time consuming, I asked cooper how long it takes DPP to install them and he said they have a body shop guy that does it for them and it takes him about 15 hours.
Ravenmad
I got my Maxxis Treps in today... :) WOW.... What a tire. They are the DOT compound radial 42s, but still very soft. I think they will be good for cruising around at KOH this year, but deff. not a road tire....... ;)
Tex68w
Beach Bum
This is my fear, they are either beyond my capabilities and they require more time to do correctly than I have available to get it done and back on the road in time to use daily.
I asked another guy who has done two sets and he said it's a solid 20 hour job if you take your time and do it correctly, so that seems to be a consistent answer.
At $80-110 an hour for shop rate/labor that can end up being a very pricey install for a set of fender flares. I wish there were a better way.
Explorerinil
I know one that works for cash and beer ?
Ravenmad
The install is really not that technical, it just takes time to do it correctly. You will need a plastic rivet gun / applicator tool for the inner fender liners, also a body saw (miniature sawzal) is a must. The rear fender flares only took me about 6-7 hours. The fronts are deff. more time consuming and require you to measure 3 times and hopefully not over-cut. If I was spending the money I would only pay to have the fronts done and do the rears myself as they are easy. I would in no way pay someone to install the front flares unless they had done it before ( I don't want to pay for someone to learn ).
Explorerinil
So what you are saying is if we drive out you will install them? Lol
Houie
