Don’t get upset ... It was in response to the ground clearance.Wrong thread...
I'm expecting a new front shaft with the kit.... maybe a slip jointed one?
Another boring Transit AWD video, the rear shock brackets are like depth gauges....
These videos would be more helpful if we knew what tires they are using.
But all in all, this is a lot better than the same van with RWD - which is mostly the point.
Sounds like one reasonable approach would be to lower the subframe, but not the diff. And just have high angle CV shafts made. Another 5-10 degrees would be good for a couple inches I think. That would allow a bit larger tires and improve the departure/approach angles a fair bit.
For the front axle, I know this is a crazy idea, but could you do a drop with gears like you would do with a portal axle? You would need three gears of course and an output of 1:1. Maybe something that bolds to the trans, diff, or maybe a mid-point cross member.
Yaw!
The AWD Transit being around 15k less than Sprinter will be a huge selling point. And nationwide Ford dealer support. And 3.5L being a fantastic engine (aside from direct injection carbon buildup).
But I am a bit bummed it's looking like it will prob cost $5000-6000 to lift an AWD Transit. Custom high angle CV's have gotta be over $1500.
When you include the lift kit, calibration tuning, tires, and of course labor....$5000 isn't feeling too wild now
With parts/labor/tires/etc you're # isn't too far off. Still much cheaper and hopefully more reliable than the Sprinter.
