New 270 Awning available.
alia176
Everyone,
Kindly put the name of your awning associated with the pics you post up as it helps us connect the dots. Otherwise, it becomes a scroll fest to see which awning you are discussing on your post! :)
2.ooohhh
Here’s my batwing from behind. Quite a bit more coverage than the 23zero you posted.
Same awning on my old FJ. You can see, NO coverage over the front fender but solid coverage on the rear and side on which it’s mounted.
alia176
That's a good one of the Batwing, thank you.
I'm wanting this area covered more than my Batwing, hence looking at the Darche or the NVS and also for the pole free standing feature.
23Zero
OVS
Darche
adaml
The Baroud is pretty nice but I seriously love my OVS awing and it's a lot cheaper than the Baroud or RLD options.
Romer
When I went to gamiviti and looked at both a deployed 23Zero and Batwing, they both looked like they had the same coverage to me. I went with the 23Zero, but it was close. Each had advantages
Mgyver1
There’s also the Kinsmen 270 that appears to cover a great deal in the back. Not as much coverage to the front but it apparently is very strong and doesn’t need support poles unless you’re going to have winds over 55 mph, snow loads over 3” or you plan on hanging a hammock from it. Weight appears to be 70 lbs and a price tag of $2,150.
It does have some cons such as the price, the front coverage and not including the support poles it would need to accommodate those unique listed scenarios. Pros are it’s made in the USA with US materials and it’s probably the most sturdy out of all. Just thought it might be included in your list.
adaml
Looks nice but other than the price, I would also add to the list of cons being the fact that he says there is a 4 month lead time associated with these orders and that it's now a "side business" for him ... Doesn't give me a great feeling when it comes to support for the product.
alia176
I'll bring this info down here from my thread on page 2 and update with latest info:
Alucab Shadow awning - 24kg/51lbs https://www.alu-cab.com/product/270-shadow-awning/ $1,500
Rhino Rack Batwing - 47lbs http://www.rhinorack.com/en-us/products/sport-leisure/shade/awnings/batwing-awning-left-_33100 $800
OVS Nomadic - 72lbs https://overlandvehiclesystems.com/...lack-cover-universal/#product-tab-information $1,000
Peregrine 23Zero - 51lbs https://23zero.com/product/peregrine-270-us-drivers/ $1,000
Darche Eclipse - 48lbs https://backwoodsoverland.com/product/darche-eclipse-270-awning-drivers-side-generation-2/, $1,150
RLD DESIGN GhostAwn 360 Awning - 68lbs https://www.rhinoadventuregear.com/products/rld-design-ghostawn-360-awning, $1,400
Howling Moon 360 6 panel awning 2.5m- 38kg/83lbs with reflective material - https://www.howlingmoon.com.au/product/6-arm-270-degree-swing-awn, $1795 AUSD
Kingsmen 270, 70#, https://www.kinsmenhardware.com/products/awning, $2100+4mos lead time
James Baroud 270, weight? https://adventure-ready.com/store/james-baroud-falcon-270-awning/, $1500 (driver side only)
PNWav
