The Wanderers build
superbuickguy
It was a fun weekend with my wife - but the Blazer had to languish, alone, in the shop.
That said, parts did arrive
the bearing to adapt my t-case to the NV4500
I may use the spare case since it's mostly apart
where the bearing goes
brake lines
all was not happy because the rears are a 7/16 banjo fitting rather then 3/8 (like the fronts).... so reordered those and these will go into the brake line bucket
front shocks arrived and they're 'just right' for length
superbuickguy
More parts arrived today... rear shocks
also the dies for putting pipe beads
directions were non-existent but figured it out
and a bead
then paint the cross over coolant tube
figured I'd use the later NP205 (one is a 77, the other is a 78 - the 78 has 30 spline outputs
the onto taking the NP205 apart so I can get the bearing bored
for reasons below, I didn't have the patience to knock this roll pin out
then an unintended visitor... quails are cute but utterly stupid. Of course, Luigi was in heaven
fun fact, the quail will sit on the fan until it gets flinged off...
and the other visitor - waiting for its tow to get fixed... again. lord I hate Jeeps
superbuickguy
so today's distraction - make a shelf for the portable ac for my wife's truck
repurposed a dog dish stand... attached it the seatbelt anchors
and created a second shelf for the 2nd 24v battery
installed
in Blazer stuff, the np205 is fully apart
superbuickguy
brake lines arrived... yay-ish
so here's the deal - no one had the parts to make one-piece lines. So I got to make up more universal... which isn't a huge issue except it has 2 new places for it to develop leaks... just for the record, all that new leakiness didn't save me much money either.
fuel filtering... decided to use a Chevrolet Colorado/Silverado (it's the same) fuel filter set up. Has a pump inside and as long as filter makers keep making filters - should work pretty well...
and got the seals and a rebuild book for the np205
superbuickguy
back to the transfer case
it fits
cleaning and working on subparts
but still parts to buy... I need 15 of these
need 2 good ones, have one
need two good yokes - since I'm getting new driveshafts, I'll upgrade to either 1350 or 1410 u-joints on the front and a flat so I can use a cv-joint
superbuickguy
back to the Suburban.... first, kill the wasps
this might be the problem... I hope so..... I had a wire overheat and thought I fixed it all... I didn't
I did now
I'll say this to remind myself. I'm the type who'd rather just go online and order something. However, because this build has some nuance, I reached out to Tom Wood's (driveshaft company) and asked several questions about what yokes I needed for my t-case. Beside giving me all sorts of great answers, it also saved me money AND got me a part that isn't listed on their website. Pictures when the parts arrive, but my experience reminded me that it can be quite helpful to simply pick up a phone....NP 208 front flange works as a rear flange a NP205
the only difference is the outside diameter of the np208 flange - not optimal, but free... thus perfect
the whole point of switching to a flat flange is to lengthen the driveshaft to reduce angles... sure, not a lot, but a bit is better then nothing
superbuickguy
OMG FIRE!!!!!! quick, get the explosives out of the shop (on another forum someone was proclaiming that I need another building for chemicals, welding gases, and any other flammable stuff.... oh and a fire system in the shop (which is all steel).... smh
in other news, welded the brackets for the shocks on the rear axle and the tabs for the brake lines
and mounted the T for the brakes
the other news was I spent quality time cleaning and rearranging....
superbuickguy
I haven't hit it yet, but it was just a matter of time - the problem - you can't reach the bolt heads on the frame without removing the tank or the bumper. You can't remove the bumper without removing the hitch... and the tank is mostly full... so I used fire*
sadly the fire system I don't have nor the safe space for flammables was used in this wonton demonstration of irritating fire officials
I also think several lithium batteries were in their chargers too....
also painted the transfer case... that was out too when I torched off the hitch....
I know this is silly, but I'm going give one last shot at getting the hitch out...the right thing to do would be to stuff a m80 inside then heat the outside with a torch....
also ran the lines for the rear brakes then hamfisted a fitting so now waiting for parts
looks good, though
*note, on another forum someone told me I was very unsafe because I didn't have a fire shed (for flammables) and a sprinkler system in my all steel shop.... then proclaimed he got a fire badge out of a cracker jack box.... (okay, the last 6 words were ad-lib)..... as such, and since I'm a complete respector of authority and their stupid rules.... I mock. I know, seems so unlike me... lol
superbuickguy
time to get a bit of paint on the bare metal
and finish the brake lines... but to fix means taking more apart...
remove the lines, rebend the lines, move the connection to behind the spring, drill a new hole and connect
and done
of course, had to hamfist and now I'm waiting for a new adapter (leaks)
front axle had a 1310 u-joint, now 1350
the old one, good thing I changed because it had a worn spot (would have leaked)
and done
went with flange type u-joint plates - gives me a longer driveshaft
then bled the clutch
only way to bleed
good spot for this
superbuickguy
continuing with brakes, but after a commercial break with the Suburban
I finally got a code (36 and 81). 81 I know about - when I bought the truck the seller mentioned the transmission was starting to go... that was 40,000 miles ago...anyway, 36 led me to a Youtube video that ....
this little bit is a bunch of resistors that go bad over time. When I put this new pump on it, the resistor bit was missing...for good reason, you don't need it
simply remove it
and plug the other 'end' back into the Optic Sensor
now, before anyone gets excited - I've done everything else to fix the surge problem....thankfully, this is pretty easy to test and that will happen tomorrow
now back to our regularly schedule Blazer update
got more shiny bits - there were enough bearings that were questionable that I bought new, Japanese bearings
and the right seals for the new output flanges
then continued with brakes.... this time e-brakes
needed to make a bracket to attach to the OEM brake cable
attach to here
like this
and then
didn't finish because it seems I managed to 180* install stuff... ah well
superbuickguy
what's wrong with this picture? everything.... first the bracket attached to the caliper is attached to the wrong caliper, second the caliper is on the wrong side, and finally, the bracket on the axle is in the wrong spot... pictures
now correct
had to extend a cable
and I got the last parts to adapt the nv4500 to the np 205... this is as bulletproof as it gets... nice pieces
adapter that allows you to 'clock' the transfer case (if you wish)
this is pretty cool, it replaces an aluminum part that's actually leaking on mine...
Advance adapters ain't cheap, but it's solid quality. 4x4lugnuts (the JO who put the calipers together.... not so much)... here, let me put him out of business. The cable set is a wilwood part, the calipers are simply 1977-79 Seville and El Dorado rear calipers. Save yourself money.... don't use him. I suppose I wouldn't be as annoyed if his advertising is "well, you can save money or save time with my parts"... how does he figure? can't tell his right from left.... screw him, the parts are available elsewhere for less money AND you'll get pictures that actually mean something.
V45W_Proto2.5
