Isuzu npr 4wd
gator70
It wasn't cheap, about 1000 euros, I have the plans somewhere
Thank you for being honest. This helps me alot.
My retractables steps, with a aluminum slide out platform, steps following the side of the habitat. Parts alone $520-$540
My labor, and a small charge for a aluminum welder to "tack" the platform aluminium beams to each other. Full welding not required. Since in addition I use pop rivets. This will be a 500lb slide capacity.
gator70
Decisions to build – buy a expedition truck
Goals when deciding what platform, and how it should be used.
My goals
  • Not longer than 23ft
  • GVW 14000lbs
  • Good ground clearance
  • Reasonable fuel economy
  • Seating for more than 3
  • Sleeping for more than 3
  • Able to be off grid for 14-21 days self supported
  • Mechanically easy to fix, without overly complicated features
  • Four season capable
  • At least 100K miles durability before rebuild
  • No rust and with good maintenance history
gator70
Rear bumper fabrication
Requirements
  • One spare tire swing away carrier
  • Two tail lights
  • Tow hitch
  • H-lift jack mount
  • Bracket for two 20lb propane tanks
The habitat is about 86" wide
Tire carrier mount is installed last, due to tail light placement
When mounting bumper on the rear of the Isuzu frame, the factory has left and right bumper brackets that bolt to the frame (four bolts each side). It seems logical to use these, then weld fabricated arms to them with 8 inch 3/16 plate triangular gussets.
The bumper has two 2"X3" 1/4 inch tubes welded to the back side for strength.
Bumper was sourced from smaller school bus.
gator70
Drivers seat replacement
Attached is a diagram how the factory seat looks and works
The seat cushion with frame lifts off for engine access underneath.
I have a replacement seat. Very nice
1) I consider removing the factory bottom seat frame and asking a upholstery shop to replace the cushion with the one from my replacement seat attaching it to the factory seat frame.
2) I plan to retain the slides and seat belt bottom mount
3) For mounting the back of the seat, it seems it all is specific to retaining the left and right hinges. Then pulling back the upholstery in those areas on the replacement seat, and fabricating the left and right mount for the factory seat hinges.
How I approach this engineering, is the discussion I hope to initiate.
gator70
CAB rear access door
I have the access door I can buy. (24"x30")
What is the suggestion how I merge this with the cab rear sheet metal?
gator70
Progress
(55mm composite panels) Steel frame as subfloor mounted to light underside frame - matched to my CAD subframe design using 5 inch c-channel.
Dimensions 5740 mm x 2200mm x 2100 mm (3700 mm on truck frame design with 440mm aluminum storage box on the rear) Six spring mounts - with dual 1 inch springs providing 5 inch movement on the rear and 3.5 inch movement on the front
All season design with water tanks heated and inside
Cab over trucks have tall cabs, unlike Earthroamers.
gator70
I have to give you an A for ambition!
However as the saying goes: The proof is in the pudding!
How about you first build your rig. Field test it for a year or two. HONESTLY post here on ExPo about your failures (and successes)!
AND THEN START TO PITCH your "pipe dream"!!!
Man I'll tell'ya, myself and a lot of the other OG big adventure truck owners ( with decades of experience) here would have to take off our shoes to count the number of times that guys ( mostly with more dollars than sense) have tried to pull off what you are attempting. And most of them tried while it was in the middle of the expedition vehicle "craze", not after "that ship has sailed"!
BTW: I have not seen one success in my 35 years of owning Casa Azul!
By any chance have you perused the for sale section here on ExPo recently?? LOTS of people trying get out from under their "dream rigs" and selling them for far less then they have into them!
Proof ? - Success ? - Pipe Dream ?
gator70
Completely build it up. Drive it off-road for a few years. Learn from your mistakes... Then get back to us!
Quick question, how do you plan to lift the cab when you have a "cab-over" box?
I'm not the first that has a over the cab habitat.
There is large engine access in three hatches inside the cab. (crew cab was not engineered for cab tilt up)
For issues like a complete engine overhaul. The habitat must be lifted off (18 bolts)
The history for this design, is it was a flatbed habitat with four motorized lift jacks for frequent on and off activity. Habitat is fully contained.
gator70
Composite floor attachment to subframe
I watched a video about Total Composites methods. I do feel it is weak
Opinions?
gator70
Probably should link to the specific video that you want opinions about...
The video I watched is one of their customers explaining the instructions given to them after the purchase.
As a summary, as I understand it, a steel tube is inside the composite panel foam core during the composite panel manufacturing.
Inside the foam core.
Then the customer is told to drill into this tube from the outer surface, and use a 1/2 inch blind fastener.
If I am correct in my understanding, this steel tube, blind fastener and the foam core is the only point this tall 3500 lb structure is bound to. And from what I did see the amount of theses points of connection is limited to ten.
Will that "foam core" hold theses ten fasteners during 60-70mph cross winds on the freeway? Where I live this wind is common.
rruff
There are fiberglass tubes in the core and the steel inserts fit inside this tube, and the bolts thread into these inserts.
I kinda think that if Godzilla grabbed the rig by the camper, picked it up and shook it... that part would be fine.
SkiFreak
Crazy Person
As far as I know, Total Composites is a reputable company, so I would doubt that they would put anything to market that was not tested to be strong enough.
If it wasn't strong enough they could be sued if something went wrong. I doubt they would put themselves in that position.
gator70
My son is PHD and did his thesis on Design and Analysis of Bolted Joints (DABJ). mostly for ocean bound wind electrical generation.
He warned me about this composite panel connection to the subframe.
I suppose this might be too technical to discuss here.
This company takes this engineering solution more seriously https://www.rvglobetrekker.com/iso-habitat-corner-mounts
Joseph McCormack
