2020 Overland Explorer Vehicles (OEV) CAMP-X pop-up slide-in pickup camper (renamed "Back Country" as of 2023)
Crux
Hi @Crux
Typically a scorched connector means a problem with the female connector's contact to the male tab. The connector could have been malformed and too loose or perhaps bent during install and didn't make adequate contact with the tab.
The fridge still working with a blown fuse is the troubling part. I believe these fridges only have one pair of inbound conductors and all fridge load (compressor, light) draw from there. Something could be mislabeled (the fuse block). Or the fuse blew after the last time your fridge had power. Test both sides (positive probe of a multimeter) of the fuse block (and negative probe grounded, of course) and see where you have power. Repeat both with and without a working fuse in place. Of those four scenarios, you'll have 12v power before the fuse now matter what. You'll only have power after the fuse if a good fuse is in place. If you have power after the fuse slot with a blown fuse or no fuse, something is dangerously wrong with that fuse block and needs further investigation and likely replacement of the fuse block.
You may want to temporarily wire up the fridge without re-installing just to ensure it functions properly before you go through the trouble of permanently wiring and reinstalling.
Review the Dometic owner's manual for your specific fridge. It will say max load of the fridge and so will the fridge label inside the fridge. You'll be able to figure out the appropriate conductor size for the load and conductor length (the length of the loop, positive and negative, from the fuse block to the fridge, which is likely rather short). These don't draw much. Probably only a max of 3 or 4 amps on 12v. Maybe 5amps on startup. Conductor size can be fairly small and still be adequate and there is no value in wiring in larger-than-needed conductors.
A fuse needs to be sized to protect the smallest gauge wire in the entire run. Don't upsize the fuse as you are not changing the wiring inside the fridge housing and upsizing the fuse may mean your fuse will take higher amps than some wire somewhere in the path.
This is very helpful!
I tested the power on both sides of the fuse slot. Everything looks good.
I replaced with new much longer wires wrapped in a loom so I can easily pull out the fridge if needed in the future along with the same 15 amp fuse.
I think the problem was the female spade connector that plugged into the back of the fridge.
Over time (4 wheeling), this connection must have loosened and then caused a short.
The new spade connector is very tight.
Should be all good now. *crossing fingers*
wackyhacky76CO
Hi Everyone! We are considering an OEV Backcountry 6.85 for our next camper. What's everyone's opinion of nasty windy nights? We are coming from an Alu-cab CC wedge that could be very noisy on a bad night. Wondering how much flapping or so forth you experienced on bad nights with an OEV pop up. Any input is appreciated.
Chadx
♫ Offroad, again. Just can't wait to get...♫
Due to the very thick, insulated soft sides, the OEV are one of, if not the, least flappy softsides there is in a poptop camper. In extreme winds, you could hear the howl of the wind, and entire pickup rocking on the suspension, some sucking in and out of the softside, but no flapping.
jschuman
Ditto to what Chadx mentioned above. No flapping, if winds get aggressive enough you're going to feel your truck moving and the general wind noise from that and the area around you. Backcountry/CampX will be solid.
We have one loaded with a bunch of lighting / electrical mods that will be getting listed for sale today, located in PHX. Family grew in size, so we needed to upsize. If you want details on it LMK.
I agree with Chad. The pop-up material is pretty taught when the roof is "popped" and so there is minimal, if any, "flapping". I've owned 4 vehicles with pop-up tops, and the OEV design is among the best, if not the best.
I do wish that the OEV roof popped a bit higher, so that I could sit up while in the main bed. But, that would add more surface area to the softsides and so the whole rig would be more suspectible to high wind.
MisterSmith
You must be very tall. I have no issues sitting upright in the bed. I actually wish OEV would make it shorter to increase the fuel economy.
Good catch. Actually, I'm short, so I'm thinking that the Backcountry/CampX must have a taller available "headroom" compared with the Hudson Bay (which I have.)
I cannot sit upright in the bed of the Hudson Bay. To be fair, I have the under-bed storage option, which eats up a few inches of headroom. But, even without the underbed storage it'd be tight for me sitting up.
tacollie
Glamper
We have the under bed storage in our Camp-x. I'm 5'9" and my wife is 5'7". We can kind of sit up if we slouch some.
Crux
OEV makes a new “tall” version of the HB popup that is 2” taller inside. I have a Camp-X and never had an issue sitting up in bed.
Does anyone know the exact height measurements of the Camp-X compared to an HB for the bed area?
wackyhacky76CO
I realize, as outfitted, most Camp-X/Backcountry units have everything you need to get started, but has anyone ever had to do any penetrations/cut outs into a sidewall or roof for something they wanted to add or do that wasn't offered in their unit from OEV? Curious as to the nature of the composite material and what would be required if so.
Chadx
I never did any large cutouts, but I did drill the roof to run solar cables through. My 2020 CAMP-X didn't come with solar. Very simple to drill and seal. You can seal with Sikaflex or similar sealants.
The panels have changed over the years, but not drastically. There are videos of a panel cross section somewhere but it's pretty basic (honeycomb panel sandwiched with foam and exterior fiberglass/gelcoat is my recollection).
What kind of project (and opening/penetration) are you considering?
wackyhacky76CO
It would mainly be OEM similar stuff like mounting electrical ports or water fill ports. I found a Cross Country which is the bare bones model, so I would definitely need to some some of that kind of work if that is the way I go.
Chadx
I would expect small penetrations like that to be of no consequence. I'm sure OEV, or a dealership, would be happy to confirm. But what you are doing doesn't sound like it would impact the structural integrity since it aligns with that they do at the factory. Not like you are cutting out an opening for a 6' x 4' window that take ups the majority of one of the side panels.
MisterSmith
There's a picture of a cross section from a post I made here
