Outfitting my Grenadier Trialmaster
jscherb
I completely understand. I vaguely remember from when you were weeding out your Jeepy things, you aren't that far from me. I've already made changes to my GX, so I'm by no means stock and therefore likely of greatly-diminished use. But I'd certainly take one for the team and drive a backup rig for time needed if you had thoughts about the GX. And I won't hijack this thread anymore with my selfish interests, so feel free to reach out in all of your spare time if you were so inclined.
Again...awesome work.
One of my challenges with the Toyota market is the large number of models and variations out there. With Jeeps it was easy - one new model every ten years or so and mostly something designed for one model would fit every variation and trim option of that model. And the Grenadier is easy - there's only one model so far and only one very small difference between the Trialmaster, Fieldmaster and station wagon as far as storage products are concerned so anything I come up with is going to fit every Grenadier out there.
But which Toyota to start with? Taco? 4Runner? Land Cruiser? Tundra? Something else? And what year/trim variation? I wish I knew enough to answer those questions, then I might work on trying to find one of those models I can borrow to do some designs. Also, Overland Outfitters doesn't have any marketing presence with Toyota, so that would be a new investment for them and they're a small company so that would be difficult. In the Jeep market they've got Quadratec and Extreme Terrain; in the Grenadier space they're just about to have a key player in that market carrying their products so that's easy. I wonder if there's a company in the Toyota market that would like to private label Toyota-specific products designed and handmade by Overland Outfitters - same quality and styling as Overland Outfitters has been known for, but marketed by a Toyota accessories company that knows that market?
grimmbusiness
In order to carry anything in the cargo area of the Grenadier I needed to find a mat to cover the slick plastic floor. I considered the (expensive) mats that are on the market and decided that I could DIY something very effective for about $30. I started with a mat from Lowes, cut it to size and shape and then cut slots for the L-tracks in the floor. The color is a nice match for the interior; the texture looks great and I won't care much if I get it dirty - I can replace it for $30 when/if I need to.
The mat I used:
After trimming to fit and before I cut the L-track slots:
View attachment 874251View attachment 874252
With the L-track slots cut:
View attachment 874253View attachment 874254
It's proven to be up to the task of preventing cargo from sliding around while on the road and it looks like it belongs there.
How did you cut it? I used an old box cutter, which worked fine, but feel like there’s a better way.
grimmbusiness
I used a new box cutter, and cut using an aluminum yardstick as a straightedge to ensure the cuts were straight.
Thanks! Will try that out. I currently have two mats - one on the plastic floor, and the second one on top of a wooden platform I build (which is level with the middle seats once folded). I spilled some lamp oil on the top mat and it’s warped in one corner, so will probably replace it once my OCD overcomes by cheapness!
grimmbusiness
When I was shopping for my Grenadier I considered adding the factory front receiver - I use a receiver-mount winch on my three Jeeps and planned to use it with the Grenadier as well. Unfortunately the factory front receiver is only rated for moving trailers around, it's not rated for as much force as a winch can provide when getting the Grenadier unstuck.
So I ditched the idea of adding the factory receiver to the front, and decided I would need to build my own receiver as I've done for my Jeeps. I've designed and built "quick install" receivers for the front of the Jeeps which bolt in place/remove in minutes - since I only need a winch (and therefore the front receiver) when I'm on an expedition, I can install the receiver and winch just for that expedition and remove it for daily driving when I return home.
I've designed a quick install front receiver for the Grenadier and I am getting ready to build it. These are the main materials that will be used... a Reese Class IV (10,000 lb.) hitch for some pickup and a piece of 3/8"-thick steel angle:
It'll go together approximately like this - the steel angle will be cut into brackets that attach using the bumper bolts that are behind the plastic trim on either side of the center of the bumper. The Reese hitch will be cut to fit between the brackets and welded to the brackets; there will also be tabs in the back which have holes for bolts that go into factory holes on the top of the bumper into the frame. I'll have it powder coated once it's built.
Installation will be simple - remove the two plastic trim pieces (4 T-30 screws on each side), remove the 4 bumper bolts into the frame on each side, position the hitch to replace those bolts and tighten them down. Should only take a few minutes and removal will take about the same time.
I'll install it just for expeditions where I might need the winch and remove it when I get home, same as I do with the quick install receivers on the Jeeps.
This has been on my mind lately - thinking of putting PakMule pro in the front hitch, so I can have a motorcycle carrier in the back hitch.
jscherb
Overhead L-tracks
As an experiment I decided to add L-tracks above the side windows in the cargo area - I've got a bunch of ideas for ways to use them to increase cargo capacity. In this post I'll describe what's involved in adding them and as I implement some of my storage ideas using the L-tracks I'll post those ideas.
There are four 8mm threaded holes behind the cargo area headliner, two on each side behind the clip-in hole covers. In this photo I've removed the covers on one side and the threaded holes are visible:
The covers can remain in place when the L-tracks are mounted, so holes for the L-track mounting screws need to be made in the covers. I made this template to accurately locate the holes.
1. Print templates and verify that the printout is correctly scaled by measuring the ruler printed on the template page.
2. Cut out templates closely along the lines so they fit into the recess in the plastic hole cover plate.
3. Remove plastic cover plates from headliner, center punch the hole locations and drill holes large enough to clear 8mm bolts.
4. Replace the cover plates and verify that the holes are correctly aligned with the threaded holes behind the headliner. It is possible that the holes in the cover plates might need to be enlarged slightly if there are manufacturing/assembly variations in your Grenadier. In my Grenadier, three of the holes lined up perfectly and one was slightly off so I enlarged the hole in that cover a bit.
The surface of the cover plate is recessed about 3/16", so to mount the L-track without stressing the plastic of the covers, 3/16" - 1/4" thick spacers are required. You could use a stack of a few washers, but I made spacers by cutting them out of 3/16" plastic with a hole saw.
Next decide how long you want the L-track to be. The threaded holes in the Grenadier are only about 10 1/2" apart, so for maximum L-track strength, the L-track should probably only be slightly longer than that, maybe 15-16". I decided to make mine longer as a test (24"), with the idea that only lighter loads would be placed on the longer unsupported end of the L-track. I may shorten it later if the extra length towards the back isn't suitable for supporting anything. Also at the front end, the L-track hides the factory mounting slot, so if that's to be used for something else, the L-track will need to be shorter.
The L-tracks get mounted with 8mm machine screws. The mounting holes in the L-track will not match the spacing of the holes in the Grenadier, so you'll need to drill holes at the appropriate distance. I used one of the holes that was already drilled/countersunk in the L-track (although I had to enlarge it to fit an 8mm screw) and unfortunately the second hole fell in the narrow part of the L-track so I wasn't able to use a countersunk flathead screw there because of the large size of the flathead. I used an Allen cap screw there, which means that an L-track clip can't go in that location. Shouldn't be a problem though, there's plenty of length on the L-track for attaching clips.
Once the holes are done, the L-tracks install easily - place a spacer under the L-tracks at each hole location and fasten the L-tracks to the threaded holes in the Grenadier with 8mm flathead screws, 25mm long or so. The Allen cap screw is in the forward hole in these photos.
As I implement storage ideas using these L-tracks I'll post photos. I may do an overhead cargo net first. or possible a storage bag of some kind.
jscherb
I made some refinements to the overhead L-tracks - I shortened them to 20", partly to clear the factory attachment points in the front and partly to reduce the rear overhang that's unsupported. I also did a little more work on the drill press to make it possible to use flathead machine screws in both locations.
I plan to make an overhead cargo net to attach to these, as well as some cargo bags, or possibly a rigid shelf.
dhuss
