Dual Sport Tires: Let's see 'em!
805gregg
I've got 2 sets of rims for my V-Strom, one with Tourance and one with TKC's. I only get about 3000 miles out of the rear TKC, so it's expensive to run.
West Coast Mags
TKC 80s all the way.
Bike is for sale in Expedition Vehicles.
Scott Brady
Founder
I have run the TKC80, which was quite durable. I found front tire stability and traction less than acceptable. The rears lasted only 2,500 miles on the TAT, and they were essentially toast by the CA border. Though I do not expect anything to really last behind 90+ HP
Currently, I am running the Pirelli MT-60, which is a great road and mild trail tire:
I intend to give the Pirelli Scorpion Pro a try:
jerdog53
I have been trying to decide what to go with in the spring when my current tire are done, what kind of life are you all getting on the TCK 80 when 80% riding is done on road?
HenryJ
I just installed a Maxxis M6006 130/80-18.
It is a little heavier and substantially firmer. The sidewall is considerably more rigid. The tread depth is impressive. Rolling it , the feel of the knobbys as they roll slowly on a smooth surface is about the same , perhaps slightly smoother than the stock TW31 Bridgestone tire.
This does look to be a very good choice as a match for the stock TW34 Bridgestone rear tire. For my terrain it should work well. I do like the heavier front tire with the four ply rating.
No seat time yet.
Hayduke950
After some others, I've decided the 908 is the ONLY rear tire I'll run on the 950. Good traction, and it will last 3500 miles even when I'm riding normally (i.e. backing it in, powerslides, etc. :D) The one TKC80 I ran was done at 1500 miles!
For the front, I'm liking the MT21 (LOUD on pavement, though, but I mostly avoid pavement.) If I'm looking for more road miles or just longevity, the TKC80 front is acceptable.
jesusgatos
While I don't do much pavement anymore, I've found Maxxis Desert IT's to be a really stout tire. The Desert IT was really built for long distance desert races like the Baja 1000, so speed and logetivity are its strong points. They're kind of expensive, at around $75 for a rear, but a great tire.
2nd that. They're not DOT-approved, but I prefer them to the D606's on-road and off.
jl8088
I just bought a rear Maxxis Desert IT tire for my XR650r based on all the reviews i read. Non-DOT but still can get plenty of miles on them with an aggressive tread with no chunking. I've had them on for a week so i'll post some long term info when i hit 1000 miles.
traveltoad
Aaron S
I too am running the 908 on the rear of my 950. I don't seem to get more than 2k out of it though.
For the front I like the 606.
They both can be leaned right over on the street when needed too.
Hayduke950
Well- I run them for 3500 miles. They probabably should be replaced sooner . I just had a mechanic friend laugh at my rear tire a couple of days ago- he said it was "ridiculously bad". I couldn't see the air inside, so I thought it was fine. :sombrero:
goodtimes
Expedition Poseur
I have found the TKC80's to work pretty well on the 650 (52hp), but not so good on the 800 (83hp).
How is the 908 on the street? Does it balance well (at all)? Unfortunately, I spend a fair amount of time on the freeway getting to the trails (don't trailer the bike anywhere...)...I don't mind the TKCs on the street, other than the head wag I get out of the front until it gets worn in (same problem as my 650 had with the same tires)...but they just aren't as much fun [on the street] as a quazi-dirt tire like the Bridgestone turd-wing, etc.
How stiff is the 908 (read: how big of a pain is it to break down in the field)?
Hayduke950
The 908 works ok on the street for me, but honestly I don't ride on the street a whole lot, and when I do I'm not really pushing it with the knobbies. I can say it'll slide predictably on pavement...:Wow1:
I never balance them- my wheels are octagons anyway. I find them really easy to break the bead in the field- had to do it several times. I carry small 8 in. irons.
FWIW I've heard nothing but horror stories about the 908 front. I'd stick with a TKC or 606 or MT-21 front... I've tried them all and I like them all for different reasons.
DanoWall
