Cheap Fridge <$400 shipped
grahamfitter
I found that the 12V plug doesn't make a good electrical contact with the West Marine outlets I have in the back of my Jeep resulting in the fridge switching off. I replaced the plug with one from Radio Shack which works fine and will do for the short term while I find a better style of 12V electrical connector.
Cheers,
Graham
LexusAllTerrain
I snagged it for 314.10 total!
Great price should be here by the end of the week. :wings:
Super deal!:wings:
I hope to check it out soon!
jfarsang
Bit the bullet.
Came across a few extra bucks saved at livingdirect.com
10% off/5% off/$10 off/free shipping.
Came out to 416.64 shipped. It's summer and hot weather is upon us. We're going out and about soon so I didn't want to wait any longer
Thanks for the advice guys. :ylsmoke:
jfarsang
Review by another person
http://www.rockymountainextreme.com/showthread.php?t=65918
After dealing with standard coolers, melting ice and soggy food under less than ideal methods of refrigeration while on the trail and camping, I decided it was time to spring for a portable electric Freezer/Fridge. I had heard about the EdgeStar fridge on another forum and the folks that had been using that brand were quite happy with the product. I did some research on my own and found that the EdgeStar brand of products are from Texas and built in China. They are assembled with high-quality parts and have a good reputation.
The size I opted for holds 43 Quarts and will hold 60, 12 oz cans. It's the smallest EdgeStar portable freezer/fridge, Model# Model FP430. (Other options are 63 Quarts and 86 Quarts.) It's a bit on the large size, but once you get it loaded with food and drinks for a few days, the size becomes quite welcome. The outer dimensions are as follows-
Height: 20.8
Width: 24.7
Depth: 17.7
Weight is 45 lbs.
Pics for reference-
The EdgeStar is built with quality hardware, a spring-loaded carrying handle on each side, a pair of heavy duty hinges, a spring-loaded locking latch and a couple of wire baskets for placing food items into. The baskets are very handy, as you can load your food into them without having to take the fridge out of the vehicle. There are also 2 drain plugs, one on the inside and one on the outside, for defrosting and cleaning out the inside of the fridge.
The EdgeStar freezer/fridge has 2 power plugs, one for 12v or 24v DC power from a vehicle (by way of a plug for your cigarette lighter)and another for household power with a 115v AC plug for home use. Using 12V power, the unit draws 4.5 Amps. It is very quiet, I rarely hear it kick on and off. If we're traveling, the noise from the vehicle will drown out and noise the freezer/fridge may be making. If you stand right next to it, you will hear it the compressor and fan turn on and off, but even right next to it, the sounds are minimal.
The temperature control panel on the side is simple, yet allows some good options. The freezer/fridge has a operating range from -8* to 50* Fahrenheit. It also has a Fast Freeze option, which will quickly bring the temperature down to -8* when you need to quickly freeze food. You can set your desired temperature with the control panel. I've been setting it at 38*, because the temperature will fluctuate up and down a few degrees as the fridge kicks on and off and temps in the car change.
The case of the freezer/fridge is very well insulated, it will maintain the internal temperature for several hours without power. I've been impressed with how cool food stayed over night after being unplugged. One of the neat features is that the EdgeStar will shut off if the battery is run down too far. If the battery dips below 10.4V, the freezer/fridge will shut off. Once power is restored to the battery, the EdgeStar won't turn back on until after reaching 11.8V.
With the freezer/fridge plugged in safely at home, I did some tests to see how long I could run the fridge and still start the vehicle. I let the EdgeStar run overnight and attempted to start my FJ80 24 hrs later. It fired right up without a problem. I shut it off quickly, so as to not fully recharge the battery. I let the vehicle sit for another 24 hrs and tried again... 48 hrs with the fridge running and not letting the battery charge and the engine turned over normally and fired right up.
After 72 hrs, the freezer/fridge was registering low voltage and no longer maintaining the temperature. The indicator light on the side was flashing yellow, indicating the low power. The digital temperature display still functioned, but showed the increasing temp. I'm very pleased that the freezer/fridge will run for 48 hours without draining the battery and preventing the vehicle from starting! These tests were conducted using a Orbital dry cell battery.
jfarsang
cont..
Here's the freezer/fridge loaded into my FJ80, so you can get a better idea of the size.-
I've been using the EdgeStar for several months and a handful of trips and it has been one of the best additions I've made to our vehicle. It's very nice to have cold food and drinks after a couple days out on the trail. Keeping perishables cold means eating good while away from home! The one complaint I have is the short 12v power cord. It comes with a 6' cord, which wasn't long enough to reach the power plug in the dash. After some wire cutting and crimping, I added additional wire to reach from the back where the fridge is mounted, to the power plug in the dashboard.
One of the many ways we're excited to use it is while fishing in Baja... we can freeze our catch and keep it fresh for the long drive home after the trip. I haven't tried it yet, but I hear ice cream is the best during a hot day on the trail. I'm quite pleased and would easily buy one again. I paid $380 from CompactAppliance.com when it was on sale. Normal price is $400.
Here's a link to the EdgeStar and the 43 Quart cooler for all specs-
http://www.edgestar.com/products/fridgefreeze/fp430.asp
After a recent search, it looks like this model may be out of production. If you are interested in purchasing one, I'd recommend contacting EdgeStar directly, or Compact Appliance, as they are the official vendor.
I cannot comment on how the EdgeStar compares to the ARB freezer/fridge or the Engel, as I have not owned either before. I would hope that the EdgeStar is comparable, but only time will tell if this is truly a quality product.
texaslawman
For people who have these is the 43 quart big enough for two aduts and two kids on 3 - 4 night outings? We currently take a 100 quart for drinks and a 40 quart for food. My thinking is a lot of room is for ice in these and with the 12 volt I can add warm drinks to replace the cold ones as we go.
saburai
FP430 coupon $399 delivered!
Thanks to Jessie (jfarsang) and some phone & email work on my part the next ten buyers can get $50 off of the $449 price. Use coupon code "EDGEFRZ50"
Do me a favor, call and ask for Eric. Call 800 297 6076 he is at xtn #135.
If that extension keeps going to voice mail try #118 and tell John (sales manager) to give the credit to Eric!
jfarsang
:victory:
jfarsang
Just picked it up. Just like everyone else.. I love it. :ylsmoke:
Q:
If you have the 12v connected to your aux. battery and 120v connected to shore power, is there a switch in the fridge to determine which power source to run off ?
(I didn't read the manual yet. Left it at work). :elkgrin:
Through today only get a bonus 15% off plus free shipping. Go here and use promo code above.
Just picked mine up for $381.65 total.
Can't wait to give it a test run in CO next month. Will post review afterwards.
Thanks for the help everyone!
teotwaki
Excelsior!
Q:
Automatically switches to AC when that is available.
