finished my rear shelf system. the point is to allow me access to the spare tire and the old spare compartment easily when the jeep is loaded with camping gear without having to unload everything.
loaded up with average daily-driver/trail-rig junk:
the spare slides out when needed, and i store the spare face down so that the empty inside easily holds a small hand-bag that i got from Big-Lots full of spare parts:
between the shelf/tire and back seats is more empty space that i plan to fill with spare axle shafts and spare fluids:
then my favorite feature is a slide out table on lock-in/lock-out Accuride 18" ball bearing slides. it's oak veneer, finished with a stain to match the fake OEM wood in the jeep, with about 6 coats of polyeurothane, sanded in between in coats and steel wool on the last coat:
matches pretty close:
the enter thing is 3/4" birch plywood except for the shelf is 1/2" oak. there is aluminum angle on the front, middle, and back to help keep the top from bowing hopefully. there is also aluminum angle on the bottoms to use for mounting. i mounted it with a bunch of large self-drilling sheet metal screws.
the Acurride slides are awesome, perfect motion and quiet, and they lock in and out with the little thumb levers on each side. the 3/4" plywood i think will be sufficiently rugged.
my only regrets thus far are that i used Rust-Oleum bedliner in a spray can, it's a decent finish, but not nearly as nice as something like Raptor-Liner from what i've seen pics of. i wish i'd gone with that and tooken the time to fill all the little screw holes and what not before lining it as i thought they would just fill in with the liner more but didn't.
other issue is the 1/2" shelf is warped a little, should have used 3/4" for that as well.
also, make sure you account for the compression of the carpet and padding when you screw everything down if you do something like this. i didn't and therefore my tire just barely, i mean barely fits! in the end that's good as now i don't have to wedge anything in there to keep it from bouncing inside the shelf, but it could have been a bad miscalculation if i were cutting my tolerances closer!
