2017 GM vans
180Hp and 360lb ft is not enough grunt to call it a 2500 or 3500 van. If it can't tow 8000+lb relatively easily it isn't worth much. I would see value in adding the 2.8 to the 1500 lineup, but not the actual work line. Another bad move GM...
Scott
Those numbers are relatively close to that of a 4bt cummins and those have been pushing around loaded step vans for years.
While I agree I would not want the 2.8 Dmax for my personal vehicle I can see it being useful to fleet managers running loaded up service trucks.
I think the diesel engine for the GM Van will be a plus for the Conversion Van market for larger vans.
Not everyone needs to pull a large trailer or camper.
I drive a full size AWD GMC Conversion van with a 5.3 gas and get about 17 mpg average , have gotten 17.8, not overloaded and 2 people
I can see a small Diesel engine in these types of Vans with the hope of better gas MPG.
Choff
Here is another source for information on the 2017 GMC van from gmfleetorderguide.com. The cargo liner spray in sounds like a good idea. The above link source says:
Deletions:
(LGH) Duramax 6.6L V8 Turbo Diesel
(LC8) Engine, 6.0L V8 SFI Gaseous
(FHZ) Dedicated Compressed Natural Gas (CNG) system
(G7J) Rainforest Green Metallic
(UFM) Fuel tank, 3-tank configuration
(UFP) Fuel tank, 4-tank configuration
(KG3) Alternator, 145 amps
(GHO) Rear axle, 3.54 ratio
New Features:
(GPA) Graphite Metallic
(CGN) Cargo liner, spray-in
(KG4) Alternator, 150 amps
(UY7) Trailer wiring, changes from 7-pin sealed connector to dual 4-pin/7-pin sealed connector
I know many a 90's trucks that had that kind of power. Including ¾ and 1 tons.
Not going to pull 10,000 pounds effortlessly up a mountain at 70MPH. But they will get around fine
I agree. The early TBI 454 engines where rated at 230 hp 385 torque I think, and that was the big engine. Plenty of smaller 350 engines put in heavy duty trucks as well.
rocksandtrails
