AT Comanche upgrades
I'm sure you did your research on the long arm setup but I see some potential problems, especially for a rig that will see long trips into the backcountry.
1st:
I see you have a heim joint to mount the UCA to the lower arm and a RE flex joint to mount the lower CA to the axle. I assume the axle end UCA is using a factory bushing. With that assumption I would like to point out that with a Radius arm type setup it relies on the flex of the bushings to alow the axle to articulate. Now I understand you are not building a rockcrawling flex rig but over time those little factory bushings that are absorbing all the binding from the ridgid radius arms are going to get trashed and I personally would rather not want to replace one or both of those trailside. The other issue is by only having one set of bushings to absorb the binding you are putting alot more stress on the brackets, joints, bolts ect-again not something I would like to repair trail side.
2nd: Again those lower link to axle joints. Remember the MJ has no body mounts to absorb road noise/vibration and by having such a ridgid mount on both ends of the arm you have no absorbtion from those annoyances(sp?) Not really a big issue but after a few hours on a washboard road or shale rock trail you will wish you had some more rubber.
3rd: Adjustability. I would add some brackets with cam bolts to gain some adjustability on the lower arms. I have run into clearance issues with my pinion yoke and the header downpipe even when at static height and the axle was centered. On a lifted XJ/MJ the axle swings to the pass side slightly on compression. You can adjust the trac bar to account for this but then with out ajustable control arms you create some axle steer. Some simple cam bolts and brackets will gain this back without having to hack the arms up. This is probably something that wont be an issue but thought I would bring it up.
All that said the fab work looks great, very top notch build. I have built several front link suspensions for the XJ platform and have used/tested/fixed them over the past 6 years or so. With that experiance I thought I would share some info one a few things I have done myself and learned from.
Fergie said:
Even with the braces that are supplied with an RE kit?
With no faimilarity with the RE kit I have no idea what it's configuration is, but Unit body designs do not take well to point loads. They want distributed loads.
The RE kit uses braces that run from the drop brackets, all the way back to the transfer case cross member.
The only kit that is stronger IMO(nothing technical to back that up) is the Skyjacker subframe, but that is more of a mid-arm kit.
Finally made a little progress on this project in the past week:
Frame reinforcements are done.
Reservoir Fox front shocks are in.
Aluminum intercooler tank has been made.
Mounts for Fox jounces made.
Next:
Currie Anti Rock.
Spal dual fan installation.
Weld in mounts for Fox jounces for front.
Limit straps for front.
Rear mounts for Fox shocks.
Intercooler tank installation.
ScottyBilt boulder bars with integral air tanks.
Funny you should ask! The custom mounts for the fox jounces got welded in this weekend. Sliders got welded on tonight. Scotty built them for me. They serve as 2 gallon air tanks will be fed by an ARB compressor. Each slider has an air chuck tucked out of harms way. More pictures coming up soon!
Here are pics of the sliders
Here are pics of the jounce & shocks
Now that is good stuff, Mario! Very nice! Scotty did a heck of a job. Be sure to tell him I said howdy!
Wow, a great truck just keeps getting better.
See what happens when you have such capable people in one place!
Looking good Mario.
TD
I would love to put those Bumpstops on my LJ, it seems like a good fit and would work well. I can't wait to see how they work for you, nice job on everything.......
I have had a soft spot for Comanche's since my buddies V8 Camaro got spanked by one, they were one of the quickest vehicles back then. Nice truck!!
Thanks for the encouraging comments guys. This has taken longer than I had expected but heck, what project vehicle doesn't.
We came up against a snag with the dual fan install, we can't quite seem to fit the dual spal in between the oem fan clutch pulley and the radiator. One thought is to remove the pulley & fan assembly if we can source the right belt while still maintaining adequate friction on the other component driving pulleys. A little more research may need to be done to figure out a solution.
We should make a little more progress this coming week. I'll post up pics as they
Nice to see things moving along! It's going to ride and drive better than it ever has. Wish i could be around for the first test. Good work Simon and Scotty :)
Bobbyjr
