Axle, diff & locker input needed
Assuming that the Salisbury axle is of the same strength as the apparent near twin Dana 60, it seems like further strengthening it is a bit overkill in a chassis that approaches being equal to a U.S. 3/4 ton pick-up. Dana 60's are the OE axle in a lot of those trucks and while it's possible to break a stock one in that service, it is not all that common.
michaelgroves said:
consderable snippage....
..... The only real disadvantages of having a mix of parts is that it will be more of a run-around to find mixed spares, and also, you have to know all the details of the cuckoo parts (preferably part numbers as well as the details of the donor vehicle), because they can't just be looked up by vehicle model.
This is a good place to bring up the notebook idea. ANY time you veer from stock in a vehicle prep/build I highly recommend starting a notebook for the whole vehicle. In Vintage Racing we used a spiral bound college ruled 5 topic notebook. That notebook was considered to be as much a part of the car as is the steering wheel.
In it one section should have nothing but what ever info someone other than yourself might need to get a replacement for a non-stock part. The "someone else" criteria is critical because it forces you to note what you might otherwise think that you'll remember. 5 years from now you probably won't remember that crucial tidbit of info. The other sections we used for sketching future mods or parts, various settings (points gap, ign timing, valve lash, etc.), etc.
FFT anyway.....
In my Jeep's Chiltons manual, I've written all sorts of notes about non-standard parts or parts cross-references. Made life a lot easier when it came to finding parts, since my brain was never all that good to start out with.
I started my own manual around 1995 or 6 when I made a new scratch built wire harness that included wiring for the Delco alternator, multiple fuel gauges, aux lighting, winch, second battery and a few other things. It is is a small binder that lives in the Land Rover whenever I go on trips.
I've kept the schematics up to date over the years which has really helped when electrical problems occurred. I have added additional pages to my vehicles personal manual. There is now a page with catalogue numbers for custom parts, including Goodyear numbers for all hoses & belts. Since I now have EFI with a return line, dual fuel pumps and a fuel accumulator, I have a plumbing diagram covering all three fuel tanks. There is a page covering the engine vacuum & PCV system that includes service intervals and since I have a built in propane tank with the old style filler valve I keep a copy of the new propane valve regulations that explain that older horizontal permanently mounted propane tanks are exempt from the regulation. Just in case I need to show it to someone to get my tank refilled.
Complete, accurate wiring diagrams & a custom parts list. Don't leave home without them.
M meadow build
