Diving in Head First!
I must admit that I am not overly surprised by your comments Yves, having worked in the US/Canada for nearly ten years, I hear where you are coming from. Gotta love lawyers!
Yes, my truck came with a spare wheel/tyre, a small bottle jack and the tools required to remove a wheel (along with a small tool roll that has some other hand tools). This is pretty standard here.
As mentioned, the mounting rails for the tyre winch are riveted to the chassis and it is located between the diff and the end of the chassis rails. The winder rod for the chain winch goes in through the side of the chassis rail. I would be surprised if that hole is not on your chassis rails. I cannot take a picture of mine to show you, as my custom rear bar mounts cover that hole now. The hole is quite distinctive, as it is not a plain round hole, it has cutouts on either side (like little ears) for the drive pin on the winder rod.
Without some modification, the OEM tyre winch would not have been viable on my truck because of the lift attained by the SWC and coil conversions. I would have needed to replace the chain for a longer one if I wanted the tyre to reach the ground when it was wound down. From memory, Gait did this on his truck, but had some fun locating some suitable chain that had the correct link spacing. Actually, I think that the chain he got had to be "tweaked" to get the correct spacing.
The actual chain winch is a Fuso spare part. I know that Eathcruiser used to have one for each spare that was mounted on the back of their vehicles. Don't know if they still use that method for lowering the tyre, but if anyone over your side of the planet was looking for one of these devices then that may be an avenue of enquiry.
Ditto on the hard to find Fuso's in the junkyard. I have repeatedly asked different people at my dealership: "where do they go when they die?" and gotten no answers.
Allan
Busbees is ok but he wants in person. I will not do business with Busbees unless I need it due to their high prices.
yabanja said:
Ditto on the hard to find Fuso's in the junkyard. I have repeatedly asked.....
equals
high prices set by the people who have what you want. I agree with, but that's the law of supply and demand my friend.
EDIT: check truckpaper for salvaged trucks, then call the breakers to see if they sell parts. Same goes for heavywquipment surplus and car-part.com
I will be calling a wrecker if I need a major specific component i.e. Transfer Case etc.... Otherwise it is much cheaper and easier to adapt parts from other vehicles via eBay.
Allan
We had some rare company here the other day! 3 Fuso campers in the driveway at once!
And Sakshi decided to help a bit with the new matching spare: (I pointed out that it was heavier than she is!)
Windows!
I decided to order up some modern windows. Thanks to David for his help and the use of his totally awesome air powered caulking gun! In the past I used a manual one on the Sika and almost died. This tool is highly recommended!
The cutout and install went very smoothly. Now just two more to go. With 4 days until departure the to do list is looking pretty long!
Started the spare tire mount today. Welded in a new crossmember to support it:
Attached the hoist and the threaded rod for the secondary support bracket. Little paint and it looks great!
Also installed the front hitch for the bike rack:
Given that you have quite a bit of overhang at the rear (something you would not be allowed in Oz) be mindful that weight behind the rear axle can have a detrimental affect on the truck's handling.
Also... you should have taken the last shot from the other side, to show off your new window. ;)
Owen, you said the same thing about the overhang when I first built the camper!!!
Hopefully I will have new windows on this side in the next couple of days.
Allan
I have trouble remembering what I did yesterday, so I will take you at your word on that one. ;)
My point was not the overhang, rather adding weight behind the rear axle.
I don't know where you had your spare/s before, but the further you place weight behind the rear axle the more it will affect the suspension geometry. You can get a see-saw effect in the cab, which is quite uncomfortable.
LukeSkywalker515
