DRW axles on an e250?
JPutnam
I have a 98 e250. I am in the market to make it into a 4x4. I found a set or drw axles from a 99 f350. all the bearings have been replaced and ball joints and stuff.(or so he claims) he wants $400 for the set.
Basically I dont want my van to be a dually. So I would just try and run a single regular wheel in the rear. I know the axles are like 6inches wider than the srw axles. Im fine with the extra width.
I want to do a 6" lift with 37s or 40s.
any input on these axles? should I grab them and use them? would it be just like putting SRW axles on? or would I run in to a ton of issues?
thanks all.
oh also my van is cng. Mostly street driven. like 90% of the time. has anyone made a dedicated CNG van 4x4?
im also pretty interested in how much gas milage has changed for you guys once you went 4x4. I get from 11 to 17mpg depending on how much i use the ac and the gas pedal.
That's a REALLY good price for the axles. The 99 front DRW axle is a true Dana 60, and the rear is an 80. Even if you just got the front axle for $400 you're in good shape. You could run a single wheel on it, or swap that 80 for a Sterling 10.5. I'll take the 80 off your hands! :D
That is one thing I should have considered when I was shopping for my axles. For some reason I didn't clue in that I could use my DRW from my ambulance instead of buying a Sterling 10.5
Just today I was measuring it and noticed how much narrower my new axle is compared to my dually. Sounds like I'll have to use a spacer when I could have simply used my stock ambo axle...
How easy is it to find aftermarket (lockers...) for the 80?
Cheers
Mr. D
looks like i commited to buying the axles.
ujoint, yeah thats why i was asking about them. way too good of a deal to pass on.
betarocker. thanks. I was told they were 4 to 8 inches wider. lol so I went with 6.
mr. d I honestly have no clue about the lockers. I am interested aswell. its been over 13 years since I did any truck stuff. and that was just samurais. lol.
Fj89
