FOUND Vans For Sale!
Looks like the Quigly Transit is up for sale
http://www.commercialtrucktrader.com/listing/2016-Ford-Transit--116839861
ebay: 2004 Ford E-Series Van, $65,000 BIN
http://www.ebay.com/itm/Ford-E-Series-Van-Custom-/111927180206
You might call it a Bug Out Van. I call it the Battle Van. The original conversion was done by Kroger but I had the steering redone properly by Pacific Fabrication in Gilroy CA. They did the seat installs, compressor system, auxiliary fuel tank install as well.
Basically the long list of upgrades is below.
ExtremeAire Magnum 12 Volt Compressor Part# 007-222
Air Tank 3 gallon 200 PSI rated
Custom skid plate air tank protector
Air Chucks inside and out
Air spring system
Front and Rear ARB lockers. They're connected to the air tank in series. Engagement is faster and it prevents partial locker engagement.
40 Gallon Auxillary Fuel Tank with in cab transfer timer
Amsoil filter bypass kit
NP 271 Transfer Case
Front bumper with winch with remote and lights.
Read bumper
Tire Carrier
Fuel Can Carrier that also holds a propane tank quite nicely.
4" inch lift
33x12.5x18LT Toyo Open Country M/T tires
Sliders
Sportsmobile Penthouse Electric top
Aluminess Roof Rack with 1500lb capacity
Aluminess side Ladder
2x 100 Watt solar panels
Rigid lights on all four corners of the roof rack
Motor top end rebuild including the below done less than 500 miles ago by FFR Fabrication and Repair in San Jose CA.
Bulletproof EGR cooler
Bullet Proof FICM-S
New OEM Oil Cooler
Oil coolant filter
Cool bypass system
Garret Powermax Turbo
SCT Tuner
Fuel pressure regulator upgrade
Heads resurfaced, checked for cracks and ARP head studs installed.
all filters replaced
Replaced stand pipes, dummy plugs, thermostat, water pump and belt
Interior
Stereo by Sound Wave in San Carlos CA
Interior upholstery, E track, battery box and charge controller install by Personalized Vans in San Jose, CA.
Custom Switch box for compressor, air bags, lockers, lights and aux tank fuel gauge.
6 Corbeau XRS Seats.
Heated front seats
Custom seat brackets and under body bracing for rows 2 and 3.
pneumatic lumbar support in second row
2nd and 3rd rows can be removed in 10 minutes with onboard air.
Bedliner sprayed interior from mid body down underneath the custom upholstery
Bed rug
Custom upholstery with E track and 6 joist hangers. If you don't know what E track check it out. Stuff is pretty awesome. The joist hangers can be used for 2x4s to hold a shelf to increase cargo room by a ton.
Midnite solar charge controller and monitor
Custom battery box
2X deep cycle batteries
Cobra 2500 watt inverter
Alpine INE-W957HD Deck with Nav
Alpine MRV F300 4 Chnnel AMP
Alpine MRV-M500 Mono amp
Alpine 6 inch speakers in front
Alpine 5x7 speakers in rear
Alpine SBR-S8-4 8" sub with box
Clifford 50.7 Alarm with Remote start
Front FLIR camera
Backup Camera
Full time rear view camera
Blackline Dart Vehicle tracker
Deputy Dan
