Isuzu npr 4wd
I may have missed it, but what manufacturer did you go with? Lots of interesting options popping up in China lately for this area!
Many builders are mounting electrical equipment touching the floor or resting upon the floor.
I watched a few youtubers who had water leaks and the floor was partially covered with water.
I help people fix condos that had water leaks all over the floor. Everything touching the floor was ruined.
This made impressions upon me. As water leaks can happen.
In my habitat everything electrical is 2 inches off the floor. Not perfect but some insurance.
I need to pivot on the decision for the rear storage box. The size is based on my stuff and what I want to store. Under this aluminum box is a steel support frame attached to the subframe.
I'm building a rear bumper, sourced from a small bus. With a swing out spare tire carrier. All that has to clear this storage box and door.
My main concern with this unit is the size of the cabling you need to run to it.
I did the research and I have that correct size cable installed with the 80 amp fuse.
This cable must support 12v - 80 amp load.
What about the drain tube?
2eleven
