Isuzu npr 4wd
My grey water tank is 100L
What are good ways to extend the grey water carry capacity so I can be boondocking longer?
My favorite place to dump grey water is on the verges of gravel roads where nothing normally grows, but not on the road itself.
Alternatively, dig a hole, preferably in a sandy location where it will soak away.
I avoid placing it on native vegetation.
Cheers,
Peter
OKA196 motorhome
Cheers,
Peter
OKA196 motorhome
I'm a newbie - I don't know
Here is what research states:
Never dump grey water on the ground, as it is often illegal and can cause odor and water contamination issues.
Important considerations
  • Illegality and environmental impact: Dumping grey water on the ground is often illegal and can pollute water sources, cause foul odors, and spread bacteria. Fines can be substantial, especially in areas like California, notes the American Sand Association.
  • Grey water contents: While grey water (from sinks, showers, and laundry) is not as hazardous as black water (from the toilet), it still contains soap, grease, hair, and bacteria.
  • Portable tanks: If you have a portable grey water tank, you can use it to collect grey water and then transport it to a dump station to empty it.
  • Check regulations: Always be aware of local and state regulations, as they can vary by location. Some areas may have specific rules about grey water disposal.
I also read somewhere, grey water dumped near a camp, can attract wild animals.
I'm thinking how I can use 5 gallon portable tanks. Then go to rest stop bathrooms and empty them. (or campground toilets) To do this I need to fabricate some adapter to fill 5 gallon portable tanks from my grey water valve. Or plumb in a hose and valve release outlet.
My habitat came with a battery cable and Andersen plug in the front. (could be used for dc-dc charging)
I also understood, I could place a 300 amp hr lithium battery in the truck cab between the two rear bucket seats. If it was a parallel connection, the lithium system would charge this battery. And my battery bank would increase to 900 amp hrs.
Cattle and sheep graze and poop and piss all over NF and BLM. Just to put it in perspective.
Yes, anything edible that you dump on the ground could attract critters. Bees and wasps are drawn to water if you are in a dry climate.
I don't make the laws.
I'm finding some innovative ways to mount and store the entry ladder.
As I build this I will post the fabrication.
The rear legs and rear cross members are to be removed surgically.
The sliding platform under the entry door has a 1/8 2x2 angle iron perimeter frame. To hang the staircase to one side, I used two of theses items below. With a grinder and welder, located them to attach the staircase. These provide attachment and removal.
Getting back to the grey water, most overland campers have less grey water capacity than fresh water. This means they are either not using all their fresh water they have made provision for, or they are offloading their grey water along the way (in a thoughtful, but realistic manner hopefully). I have even been in campsites in the summer, where the site operators have asked for campers to discharge their grey water around the trees on the site to water them!
Gator, is that your grey camper box? If the double bed is in that space above the cab, you must be like Wile E Coyote after been flattened by a road roller - that would give me the heebie-jeebies with my face so close to the ceiling!
  • Haha
Reactions: mog
I figure that you would have to be young and have no mobility or disability issues in order to utilize that space for sleeping. For me, I would think that 900mm would be the minimum height I could work with.
That setup would definitely not be an option for me or my wife, that's for sure, but it's not my camper. :)
  • Like
Reactions: mog
DETN8
