Truetrac works very well with the traction control because the TC will force the TT to bias, essentially doing the same thing as left foot braking but automatically. Then there is diff strength. The Truetrac is very strong and solves the weakness of the stock two-pinion diffs which TC can be hard on over time. A really great combo in a Range Rover would be Truetracs front and rear with the Borg Warner transfer case which suits the RRC better than the LT230, locks up just as well off road and has the advantage of allowing continuous shifting of torque front and rear as conditions demand, which the LT230 can't. This makes a huge difference at speed on loose surfaces like dirt, sand, ice and snow, where the continuous lock of the LT230 will actually be a liability compared to the Borg Warner. Far too many rip BW's out for financial reasons or because they just don't understand their advantages over the LT230. The only real disadvantage to the BW is that the viscous coupling should be replaced every 100K for reliability. A spare is easy to carry and fit in the field if necessary though.
BTW: An alternative to the Truetrac is the Ashcroft ATB diff. There is even a version of this to install in place of the diff lock in an LT230, giving torque biasing or manual locking as required. The best of both worlds.
