Overland Journal Project Land Rover Discovery 4 (LR4)
Thanks. I think I recall that idea but thought it was a temporary plan seeing as the spacers add unnecessary stress to the system which is already being stretched a bit. It seems that lr3 rotor swap would also do the trick seeing as I've never felt wanting for more braking on my lr3 and it has weighed significantly more than the above lr4 build.
This. I even swapped to v6 brakes to fit 17" wheels. Can't even tell a difference - all that changed was the rotor got a bit smaller, so maybe when towing a 7000 lbs boat downhill I need to worry about brake fade, but that's not going to happen.
The LR3/LR4 systems are not compatible from the ABS/ESC/TRAC perspective. The spacers are an appropriate long-term solution. Based on our feedback from LR, the bearings and ball joints are more than capable of taking the additional leverage. Even the Compomotive 18s have a wider offset.
In outfitting an LR3 with similar tires, would you recommend the spacers in order to achieve the wider stance once the vehicle is aligned for the taller height?
Others can chime in but because I have just made the attempt to use a 32" tire on stock 18" wheels, I can tell you that 32" BARELY fits and this is not without rubbing at various situations that are not even "extreme". With an LR3 you may be aware of the "nubs" "bumps" in steel that are directly to the rear of each front wheel at the bottom of the wheel well/fender liner. When you turn to 90% lock, a 32" tire will scrub these significantly.
Using a stock wheel with a 31.5" tire such as the BFG AT, will hardly scrub these unless it's a new tire and only for a moment. However, adding a 1.5" spacer effectively pushes the tire closer into that bump when turning sharply. One may get the same rubbing using a 31.5" tire and spacers that I get when using the 32" tire.
Also to consider is the width of the tire chosen. For example, the commonly used Nitto Terra Grappler is a 285/60x18. This is slightly shorter but wider than the also commonly sued BFG AT 265/65x18. Slightly wider and taller is the Goodyear Duratrac which I am trying out now. It is 275/65x18 and noticeably wider than the BFG 265/65x18 but it also rubs in the two front wheel spots as well as in the rear fender liner "bumps". This is unfortunate because this GY tire really seems better than either the Nitto or the BFG but is currently only made in the 276/65x18 smallest fit on an 18".
Spacers will often worsen situations where you need a full "tuck" of a tire up into the rear wheel well unless this is offset by using a narrower tire. An example may be comparing the clearances of the GY tire without spacers to a BFG using spacers. The end results in clearances may be similar.
The narrow, tall 33 really helped in our application. The 265 width was the magic pill. 265/70 R18.
Still trimming and other modifications are required. We are still making adjustments to fit such a large time, but ultimately, I find it worthwhile.
I run the BFG ATs with terrafirma spacers - they do rub noticeably turning when the suspension articulates on dips. A little cutting is in order of the wheel plastic liner inside but very simple. The BFGs don't rub too noticeably without spacers and IMHO are the tire of choice for those not wanting to have backups to the backups for air suspension issues.
RE: Spacers. I wouldn't change back to running without the spacers. I'm very satisfied with the wider track stance of the LR3 and when I see LR3s running 265/65/18 BFGs without spacers they look odd to me now - my perception now because visually the tires sit deeper inside the wheel wells.
I've got a set of 245/75-17 KM2's sitting in the garage
Get mounted on Saturday, then tested out on the trail on the 15th :)
Camp Tonneau Tents
