Post pictures of your Land Rover.
I agree that is way high unless you are doing maintained trails (dirt roads). Stock Series low first is 41:1 and I was always slipping the clutch and hopping from rock top to rock top with a lot of suspension stress. For 10 years I had a wide ratio gearbox installed that gave me a low first of 70:1 at the axle. For the kinds of driving I do that was way too low. I think I only needed it a couple times. And I had to switch to cable linkage to keep the engine from jumping because I could not hold the throttle steady enough.
For the kinds of driving I do, I figure the range between 50:1 and 57:1 is the low first sweet spot (33.3 inch dia tyres). I'm currently at 50:1 and it works very well for me. But I'm more of a rough terrain expedition trail type driver and not a serious rock crawler type.
That's a BIG jump between low first and second. Unless you are doing some extreme rock crawling I'm going to guess that you won't be using low first a whole lot and low second will become your primary low gear.
Good luck with whatever you end up with!
Agreed. My new crawl ratio with the 5 speed is 39:1, and it's a little high. It helps that the engine has plenty of power. I had no problems last weekend on roads that could loosely be described as roads. Fairly difficult logging roads. But I know it'll suck in any kind of "extreme" rock crawling.
Personally, I'd rather have an 80:1 first, and just use 2nd more often. "Too have and not need, rather than need and not have."
I think my plan, as funds allow, would be to change the LT230 High range ratio to 1.0, then drop the axle gearing. Say going to a 4.12 would get me nearly the same high range ratio overall, but now first gear low would give me 45:1. A little better...
But now that I look at the numbers... hardly seems worth it.
Y2kdii
New to me Kent Green 2000 DII. OME 2" General Grabber AT2s-265 75 16
Craigslist find. Took 8 or 9 trucks till I found a yuppied mall crawler that was taken care of and DRY underneath. All the maintence receipts were in the manual the original window sticker in the glove box. Needs a few things, but nothing major. Already have the winch from my last rig, just need a bumper next.
Is that an APC is see parked behind your Disco? If so what kind? I myself like the eclectic mix of machine guns and Land Rovers!
Soviet Armored Recon Vehicle
Its an old Iraqi bringback Soviet BRDM-2 RkH, armored reconnaissance vehicle.
You should definitely reconize these other military 4x4's in the line with the Rover:)
11b4v,
I see that you're in Atlanta and I'd like to invite you to check out www.solaros.com.
We are the Southern land Rover Society and we meet in Roswell on the third Wednesday every month. There's more info on the site or feel free to contact me if you'd like more info.
Nice D2!
Mike Pado
Hey Mike, I appreciate the personal invite. Ive actually tried to get to the last three meetings but have always had something come up. I'll see you there on the 15th.
Hi chaps, some nice trucks in this thread.
This is my 300tdi auto just got 300 miles under its wheels after an extensive rebuild
regards
regards
Softtop:victory:. Very nice!!!! And so is the interior! Tidy and clean!
Beauty!
All it needs now are some rock sliders.......
regards
Gren,
Whats your impression of the Wright off road sound deadening mat kit you have ? Glad to see you have it on the road now.
Doug
tbnd88
