tdesanto
flyingwil said:Looks great Tony!
No hand damage this round (like the dual batteries)... huh?
No; somehow I managed to finish this job relatively unscathed.
Spikepretorius said:Hey the Mitsu is looking good!
Looks like I've got some catching up to do on my Mitsu
Thanks for the motivation.
Spikepretorius said:Do you have a drain plug in the tank for draining water? And can you get to it easily?
I want to fit a similar system but haven't quite figured out a way to drain the tank easily when the truck is loaded.
Spikepretorius said:I reckon the tank definitely needs a drain plug.
My regular compressor in my garage get's plenty water in it and I drain it daily.
My small compressor in the truck also seems to pump significant water.
I won't fit my system till I've figured out a way to drain it conveniently.
I was also considering fitting a tank under my truck but didn't want the hassle of crawling underneath to do the draining chore.
Is there anyone else here with a bright idea?
p1michaud said:Tony,
Very cool updates. Your mod list must be getting pretty short by now!
Cheers,
P
preacherman said:t- looks good, I like the new changes (air compressor and such) how was your mpg when you went to New Mexico, any better?
Willman said:Tony,
Great setup on the Extremeaire compressor!!!!!
The fan idea is a great one!.....I would have used one..but..i used some steel mesh instead to keep the air flowing.
Oh..and keep your sweet rig.......You are all setup!.....The coolest Montero out there!
:26_7_2:
