Amphibeast
you have no idea when it comes to multiple projects………. my compound is out of room!
Titan...when will they learn? What's up with this "won't accelerate past 25" stuff? Why? Any details? Symptoms?
So many questions.
John B.
I would like to see those things if that list is real, JBFP says its real but he likes to get a good joke in every now and then.
Prescott, the last time I had a car that had a similar symptom, I was having fuel starvation problems from a dirty tank that was clogging the filters. It would idle, as well as rev at idle fine, but under load no dice. Start simple.
I was gonna say drop them off at my place but i saw the list and the first 3 wont even fit into my garage haha
you likely have a dead coil. it happens and the symptoms are exactly as you explained.
it's running rich because two of the 6 cylinders are not firing. its only getting to 25 because it's making 2/3 the power it should be (actually less) pull plug wires off the coils until you figure out which one it is, if you pull the wire and nothing changes in the idle, thats the ticket. then swap that coil with one of the working ones to make sure the problem stays with the coil, if it stays with the coil replace it, if it moves, replace the ignition module, both are extremely cheap and easy to swap and can be got at the junkyard for pocket change.
by all mean, swap to a 3.5, but get your system working correctly or you'll do a butt load of work just to be annoyed at the results.![]()
He's got a 12v, so only one coil.
They are real….. real big, real expensive & really need more love than one man's time & budget can handle these days but I tread forward! You are more than welcome to check them out… the 2 small buggies are up on the trailer covered these days… but everything else is accessible
Oh, by the way, Matt Castleberry, the guy that seems to think all things Astro van are just great, just bought a guy's '98 Montero that was being advertised through Facebook's Montero page. Matt was texting me yesterday all sad about how he couldn't find a decent Gen 2.5 or anything so I told him to look on the FB page and he immediately snapped up the one being sold by Perry Way on there. CA vehicle he just dropped about $5K in maintenance on, couple of really minor issues, fully loaded, $3500. We'll have HoseB polish it up and maybe I can try my hand at actually posting a picture.
John B.
