The Camp 4x4 Bus - 1973 Suburban 8.1 Swap & Build
Well, I countersunk the the 3 bolts today. Definitely better, but the bushing is still resting on the adapter plate. And though I didn't try it, I'm gonna say the stock crossmember is, at least, going to require a fair bit of trimming to fit.
After I got that done I spent some time taking the brackets off all the seats so I could get to work on designing the brackets to mount them.
Gotta say, the extra hour of daylight this evening was pretty nice. I feel like evenings are going to be a whole lot more productive now.
Pretty good evening of work yesterday. Solved 2 problems that ranged from a bit of a show-stopper to a minor annoyance.
The show stopper was this issue with the transfer case coming so close to the transmission mount. During the day I'd looked through pics of various custom transmission mounts and was surprised to find that while there's a number of aftermarket engine crossmembers available, there really aren't any matching transmission crossmembers. I suppose part of the reason might be a lack of demand. It seems that in many cases the stock crossmembers can work just fine by being moved back and forth on the frame. The other thing I found was a number of people DIY'ing with square tube. Easy enough I guess. Another thing I came across was a mod being done to stock Jeeps where the transmission crossmember was pretty well stuck in place. A simple bit of 1/8" or 1/4" angle iron was welded to the back section, providing a platform that was just far back enough to match the new mount location. It seemed like this would be a simple enough solution for my immediate needs (and cheap) so I picked up some 1/8" x 1.25" angle iron and a bit of 1/8" flat (for extra bracing) and headed down.
But, after a bit of hands-on with the mount and the transfer case I realized that all I needed was a bit of relief in 2 small areas. By notching the center section of the crossmember, right between the mount bolts, I could easily clear the adapter plate. And with a small notch a bit further down the crossmember would clear a corner of the transfer case that was protruding just enough to hit the edge of the crossmember.
Since I had the angle iron I figured I'd make the notch of the center section a size and shape that would allow me to add the angle iron as an inverted corner to brace the opening. I'm not even sure this would be totally necessary but it makes me feel better about cutting a sizable hole in the crossmember. This ended up working great and really not taking that long. The great part is that, when I eventually get a Northwest Fabworks Blackbox underdrive, I'll be able to keep the crossmember exactly where it ends up in this configuration, so one less set of holes in the frame and one less thing to move around again.
Now that the transmission mount is sure to mate up to the transfer case properly I'll be moving forward with installing all that and moving forward with the rest of the drive line, the twin sticks and everything else down there. :D
The other problem I solved yesterday was related to the electric lock poppers. The kit that I bought came with clamps to mate the popper to the lock mechanism. Unfortunately the clamp was too small to properly grasp the rod and it kept slipping off. While I was at the hardware store for the angle iron I looked around for a potential solution and came across the wire rope section and the u-clamps. I eyeballed the size and nailed it. Just gonna throw some thread locker on them so they don't rattle loose, but I expect they'll hold great.
I'll be back at the shop again tonight, either figuring out how to muscle that t-case in place or working on electrifying the remaining doors.
Nice fix there. Some nylocks would be a nice addition.
I would round the corners off on the crossmembers, sure don't need cracks starting!
Well oh well... been working, haven't been updating... I've got a short update tonight, more tomorrow.
Basically I've been primarily working on the doors. I'll get to an update on those tomorrow.
Tonight I got the floor bump for the driveline parking brake rotor fab'd up. Wasn't too hard, just a little time consuming. I checked clearance and the rear transfer case output flange and rotor will go off and on without dipping the whole driveline now. :) The bump is made out of 16-gauge sheet metal and just needs to get fully stitched in.
Besides that and the doors, I've been doing a little planning ahead on the interior. For a while now I've needed to figure out a good place to put rocker switches. The dash really doesn't have anywhere, and I had yet to find any other options. Finally I stumbled on Daystar's switch panel for Jeeps. This little pod is actually perfect for mounting just above the windshield as an overhead console. I plan to trim a hold in the headliner and install the switch panel behind it so the headliner covers up the screws and such.
Once I knew I had a panel to use I got to looking for switches. I've always wanted a switch in the cabin for winch in/out control. A little searching around and I found OTRATTW The Switch Guys. I didn't realize it when I ordered but these guys are right around the corner from my office in Cupertino. After figuring that out I swung by their offices and checked out their setup. Its a mom and pop place but they've got a pretty cool set of Epilog lasers doing the custom designs.
Before I left I asked the owner if he could do a custom design if I sent him an Illustrator file. He was game, so right away I started thinking what I'd want to do.
Besides the winch switch, I definitely need one for the offroad lights I plan to mount on the bumper. Since i'll be running e-fans for both the radiator and for the aux cooler, I want to have switches to turn those off for water crossings. That's where I started with a custom design. What do you think? Its Derale's 15200 dual-circuit aux cooler I'm going to be using for cooling power steering and transmission fluids.
I also picked up new arm rest pads for the door trim panels that match the dark brown of the carpet. I think they match the wood trim pretty well too and are a nice contrast to the beige of the trim.
More on the doors tomorrow...
Glad to see you making progress Aaron. Nice colour match and contrast on the door panels. Keep up the good work. Cheers, Chilli...:cool:
Another successful day working on the truck! 3 little things and 1 big thing ticked off the list. The little things really help keep the motivation up. Little by little this thing is becoming EXACTLY what I want it to be, and I know all the little things are going to make me immensely happy in the future.
The first little thing was putting a low profile latch on the gas tank access panel. When I first installed the panel I hadn't really thought about the fact that it didn't have a handle of any kind on it to pull it open. I guess with it installed on a vertical wall you can just press on one end of it and it'll open. Not so much sitting flat on the floor...
So, McMaster-Carr to the rescue. I found a sweet flush-mount latch that suits my needs perfectly. A bit of drilling later I had it installed. I did have to make a spacer out of some 1/8" ABS sheet I had around since the thinnest mounting material thickness for the latch was 1/8"-1/4" and the panel is about a 1/16".
The second little thing I did was install the hood brace kit I bought recently. The hood is in good shape currently, but I want to keep it that way, so braces gotta go on. I plan to spray the whole under side of the hood with Lizardskin insulation so the braces should blend right in when it's all the same color.
The third little thing I did was clean up and treat the rust where the rear quarter panel and barn door window seals had been. They probably got dried out in the Arizona sun and started letting water in. There were some bad areas, but fortunately nothing that had rotted through or affected the integrity of the metal in such a way that it would need body work. A little Corroseal on a foam brush later and all is well again.
And at last the big thing: I finally got a door completely back together. These stupid things have been a helluva project. After figuring out how/where to install the electric motors for the windows and the electric lock poppers, and taking the '87 door apart to get the glass out of it, I realized that the track at the bottom of the glass from the '87 is wider than the track on the '73 window. Ugh. Fortunately, while looking through LMC for new window seals I found you can buy the correct size rollers to make the swap. The old ones just had to be drilled out, easy peasy. The new ones I guess you're supposed to be able to punch or vice down like a rivet, but I just ended up tacking them in with the welder.
After a fair amount of struggle getting the seals, glass and regulator back in the door, I finally got it all together, and I'm ecstatic to have the dark factory tint on these doors! With everything in I screwed it all together, including the new armrest pad. Love how it came out... now to do the other 3. FML.
Looking good there.
I have a couple spots that are rusted on mine too and I can see where it is running out of the seems. I got some spray on rust inhibitor from eastwood that comes with a tube to get into those hard spots. Figured I would just go around the whole thing.
I agree with everyone else Aaron, your truck is coming together nicely. It must be a great feeling of acomplishment to see it starting to take shape. Thanks for posting pics so we can follow your build. Cheers, Chilli....:cool:
Keep up the good work.I always learn a trick or two ,and this makes it interesting.
Cheers Urs
Thanks guys! It does feel good. It has been a much longer project than I initially set out to do, but I'm very glad to be doing all the things I am. I'm looking forward to having a "finished" truck in the end, instead of an on-going project. Taking the time now will, I hope, yield dividends later as I get to simply enjoy what I've built. :)
I'll be back at it this weekend trying to finish up all the doors. I have the final window seals and last set of replacement rollers coming in tomorrow, and all but 1 of the '87 doors have been gutted and all the '73 doors are ready to be re-assembled.
At some point I'll have to make it out to a junk yard to grab another side window that matches the '87's OEM tint since my buddy busted one of mine while removing them. I did get the 2 barn door windows and the 1 side window I have installed. That was interesting. I'll do a video of the technique the neighbor glass guy showed me for getting these guys in. It is the typical string method but I'd had a hard time finding a good reference before.
I'm soooo happy the '87 glass and seals worked. The one bummer is that the seals don't cover down as far as the '73's did, so there's some converted rust showing. No biggie since it shouldn't continue growing now that it is converted, but just not as tidy as I'd hoped. Meh.
I would love to find the side sliders and they even make a rear flip out somewhere. Would be great to air throguh these things.
Why yes... :)
No major projects have gotten checked off lately, but I have been making slow, steady progress on completing the doors. In a recent update I'd got the first of the rear glass in. Since then I've got all 4 pieces in! There's definitely a few tricks to these, and having two or three people doing them seems pretty much required. I don't know how I would have managed these myself at all.
The barn door glass required putting the glass in the seal first, then running some small paracord in the channel that the body is supposed to go in, all the way around, so that the ends cross each other at the bottom. Apply liberal amounts of silicone lube to the rubber and the body. With your helper holding the glass and seal from the outside, and without un-crossing the paracord ends, place the paracord ends inside the truck. Using both ends still crossed, lift up and inwards on them so the lip of the seal pops over the body edge. Now work one end along the seal so it pulls the lip of the seal over the body edge. Do this all the way around and you'll have the seal in place! Make sure to keep the rubber lubed so there's no friction on the body or the string: this could cause the rubber to rip.
The side glass is kind of the opposite: the seal goes on the body first, then the glass gets worked in. Start with the one sharp corner, and the glass on the outside. Place the corner of the glass in the seal channel, then use plastic body panel tools to work the seal lip from behind the glass to in front of it. I found that having a third person with a panel tool on the inside helping push the lip out while I held the recently popped-out section in place worked very well. It is slow and tedious but it works little by little. Again, liberal use of silicone lube spray helped a ton. Once the glass is in the seal, install the locking strip. I HIGHLY recommend getting the specialty tool for this. You can do this with panel tools too, but the specialty tool makes it sooooo much easier. Fortunately there's a window guy in the same complex as my buddy's shop, so I was able to borrow his. I think LMC has them for like $20 or something... seems like a lot, but we're talking moments with the tool vs who knows how many very frustrating minutes without it. My sanity would have been worth $20.
The other Sunday I had a couple gearhead friends over as slaves happy, helpers. Colleen and her husband Glen got a ton of work done on my doors: he got all OCD on the speaker hole placement and she did a ton of soldiering on the switch and motor wiring. I'm gonna be down working on putting all the doors together now that the windows are all pulled from the '87, the seals are ready and the various holes needed are cut. I think these should be ready to go on over the weekend.
Speaking of the weekend, Saturday by buddy, Patrick, will be coming up from SLO and helping me get the Chassis Unlimited rock sliders built up! :D It's his welder I've held hostage been storing for him forever, and Saturday we're going to put it to good use. These sliders come semi-built, so all we have to do is figure out the cuts needed for the frame stand-offs then weld them to the frame plates and slider body. I'm hoping that it should be fairly straight forward since the plates will be on a nice, straight, level piece of the frame. At the very least I expect we'll get the thing tacked together so I can do the tedious final welding over the next week.
The weekend after this one my dad is coming around for 5 days, and I'm taking the week off work to really spend some time hammering on the remaining projects. Our goal for his time here is to get the thing fired up! Tasks remaining to that end include:
  1. Plumbing the fuel lines
  2. Installing the fuel filter and pressure regulator
  3. Connecting the wiring harness
  4. Powering the wiring harness
  5. Installing a starter
  6. Installing the core support and new radiator
  7. Plumbing the radiator
So that's gonna be a fair amount of work but I think totally do-able in the days he'll be here.
2eleven
