The old Chrysler V2 compressors were bullet proof but I'm sure newer models are more efficient. I remember talk of them using 15HP back in the day. I'm sure they are 134 comparable with a change in oil. ( they run an oil sump also) delete the POA valve in the top, it does nothing. There are plenty of "leaning tower of power" engines with this compressor right on the top. Brackets should be easy to find at the JY. (Dodge Dart). The under dash units have copper evap cores, little less efficient but they lasted forever with out leaks. The expansion valve is there ( mushroom deal) two hook ups are for freon lines. Just add a dryer to the hi side ( smaller line) between compressor and condenser that's also needed.
Sent by wing, prayer & ATT
