Joe, diplostrat, I'm pretty sure you've both traveled internationally with your rigs. I'm wondering how easy/difficult it was to shop for peat moss or coconut fiber or whatever it is that you use in the head while in other counties and staying out of major cities?
I like the idea of the composter and the separated pee collection, I'm just trying to come to terms with the size and understand just how much peat moss or whatever I would also need to be carrying around. We didn't use or previous toilets much, but if we found an easy, clean solution, I could see using it more often. ...
I have been trying to find a toilet solution for long term overlanding.
My wife and I spent 17 months traveling through Mexico and Central America. During this trip we mostly dug holes or used provided toilets (despite whatever condition they were in) We also carried a Luggable Loo bucket/bag toilet. We weren't big fans of pooing in a plastic bag and leaving it in the local trash pile, so we didn't use it much. We did, however find ourselves in situations where we wanted to camp, but facilities were not offered and digging holes was not an option.
We tried a chemical toilet with a design similar to this http://www.nrs.com/product/73050.02/eco-safe-toilet-system during a 2 month Baja trip, but were not impressed with the detachable "bowel" design nor the difficulty of cleaning the separate parts when a dump-station and ample fresh water are not available.
I am currently thinking that a chemtoilet similar to the one mentioned above, but with a simpler design for use away from dump stations would be our best bet, but I haven't found one yet.
Any suggestions?
The Advantage of a composting toilet is not the compost. It is waste handling that is clean, does not smell, compacts the waste(as it breaks down) and uses no water. Only requires dumping every 3-5 weeks (2 people full time) if used correctly.
I sound like a composting toilet salesman! Changing from a flushing toilet to a composter is one of the best things we have done to our truck.
Have you looked at the Wrappon toilet system ? Design from Japan.
Sealed bag with gelatin powder added with each use.
12 volt required
Pricy $800.
Lots of moving parts.
Requires proprietary plastic sleeve.( $48.00 @Cabalas) good for 50 uses.
Has a USA distributer located in Colorado.
Can Google for info
