Vandetta
Got the flooring in today.
another shot of the over head console with an addition
Now you have another to build up so you don't have to be.jealous any more!
Sent from my ADR6400L using Tapatalk
cool idea with the floor storage. was there a gas tank or spare there before? curious if you had to eliminate anything.
that looks like a lot of dynamat...how many bulk packs?
The spare tire carrier needed to be removed and I moved the body support forward above the frame support. Every thing is removable and I can make a deeper floor storage.. I kept it bottom even with the frame so there is nothing hanging down to get hung up on something.
Between the frame support and the rear axle I'm installing an overflow gas tank eventually
The dynamat was around $500 for the entire roof,doors, and floor and wheel wells.. I need a little more to finish the wall but first I'm going to insulate them... just haven't figured the best way yet.
I was going to rhino line the floor however it was going to cost over $600 just for the floor.
Switch Panel wired up
This will go in the overhead console as a main accessory control panel, lights, lockers, etc. Molex connector will make removal of the console easy if I need to add anything at a later date.
I finally covered the console with some material
Finished the slide trax in the floor, electrical components box, and covered wall panels, the box will also be a main support for the bed/dinette
Aluminess
I got my bumpers and nerf bars installed last week.. Been busy getting the interior work complete and wiring lights and gadgets
LukeSkywalker515
