Greenmonkey
Ok so, my toe-in and amber is fixed, I wanted to make them both adjustable but I couldn't figure out a way that had the very small increments of adjustment need but still be strong enough to withstand a blow from a rock on the trail with out moving. I didn't really want to use a rod end with an eccentric bushing. Well see how it works with out adjustment, I can always change it latter if I want.
I have a printed version of the drawing for the trailing arm brackets, I could take a photo of it so u had the measurements or I could cut out and bend them for u if that would help.
The trailing arms are 29" from the center of the axle to the center of the bolts for the bushings. The weld in spindles are from adventure trailers and I don't recall what they were rated at or if they even said, I think most of those rating are for solid axles so I think most of that goes out the window when u make it independent suspension. I know for a fact that they will hold anything I put in the trailer.
The trailer tows like a dream so far, tracks strait and didnt even bounce that bad. But it's a long way from being done.
I don't know what u mean by the tapper on the hitch sorry. There is a 2" long x 1 1/4" o.d. X 1" i.d. Bronze bushing in there. It might not be the strongest or last the longest but i can rebuild the whole thing in about 10 minutes. I still have to beat the hell out of it to see how it lasts.
Thanks for your complements. Let me know if u have any more questions.
