Doc's 05 Tacoma Build Thread
Dave Bennett
Adventurist
Spent the weekend at San Onofre beach with the fam. Knocked the dust off of the Jayco Baja (my wife's toy) and LOVED the way the truck tows with the new Demello rear bumper. Tongue weight seems to be perfect, nice flat tow and feels very stable at all speeds. Just like OEM ;)
Dave Bennett
Adventurist
Magnaflow
Finally got around to the exhaust. The stock crossover pipe on the 2nd Gen Tacoma is notorious for hanging just below the cross member (WTH Toyota?) and since skid plates are finally in my future I wanted that belly flat ;)
Took it to Bear Valley Exhaust in Murrieta for the surgery as well as the addition of a Magnaflow exhaust. I really like the way it sounds (not ricer but a nice rumble for a V6) and Magnaflow is made right here in USA (Rancho Santa Margarita in SoCal).
teotwaki
Excelsior!
Continuous evolution!
Any "before" pictures of the exhaust crossover? The 4Runner is a little different in that area but I am looking for ideas.
Dave Bennett
Adventurist
Truck looks great Dave but I have to comment on those crossover pipe welds. :/
Yeah, typical exhaust shop work. Not pretty but it feels and sounds great and most importantly it's up out of the way. I have some titanium exhaust wrap coming from Summit that will protect the T-case and that U-joint. Overall I am very happy with how this turned out.
Dave Bennett
Adventurist
LED lighting upgrades
I decided to upgrade all my bulbs to LED's :D
If you dont use an electronic flasher relay, the blinker will blink too fast, based on the lower load of an LED but there is an easy solution (easier than individual resistors) for 2nd gen Tacomas: upgrade the blinker relay to an electronic flasher.
Our blinkers have 8 pins so to run LED blinkers you need one CF18-08 flasher. Found here. http://www.superbrightleds.com/flashers.htm
Here are the bulb sizes for reference:
2005 to 2008 Toyota Tacoma Light Bulb Size Chart
Low Beam Headlight Bulb Size: 9003/HB2
High Beam Headlight Bulb Size: 9003/HB2
Parking Light Bulb Size: 2827 or 4157NALL
Front Turn Signal Light Bulb Size: 4157NALL
Rear Turn Signal Light Bulb Size: 3157A
Tail Light Bulb Size: 3157
Stop Light Bulb Size: 3157
High Mount Stop Light Bulb Size: 168
Fog/Driving Light Bulb Size: 9145
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 921
Front Side Marker Light Bulb Size: 2827
Map Light Bulb Size: 168
Dome Light Bulb Size: DE3022
2009 to 2012 Toyota Tacoma Light Bulb Size Chart
Tail Light Bulb Size: LED
Stop Light Bulb Size: LED
V45W_Proto2.5
