Scott Brady
Founder
I view all of these trucks from the perspective of overland travel, which is the reason I would buy them (and the reason we would discuss them here). Otherwise, I would just drive a Range Rover.
While I can see your perspective with regards to appointment, I believe that the LR4 and the Wrangler are quite relevant for comparison. They are both the most capable vehicle and utility-minded offering from two of the most iconic 4wd brands in history. You cannot simply base it on the cost differential or luxury appointment, as those elements can actually be detractors to our needs, reducing payload, reducing interior space (with panels and thick insulation, etc) and increasing cost unnecessarily.
In Rubicon trim, with the new interior and heated leather seats, they are closer in comfort than you think, particularly when you have the advantage of so much capability. You should look at the specs between the G-Wagon, LR4, Rubicon, 4Runner Trail Edition and XTerra. All very comparable. . . and worth comparing.
The tire size issue is nothing new for Land Rovers. They have always had small wheel wells and were fitted with smaller tires than the competition. I am more than happy with the 33" tire on the LR4. They are already bigger than any tire I have ever installed on a Land Rover. My DI is running 30s, and does just fine for my needs. Of course, the LR4 is a bigger vehicle, so the 33 seems to be "just right"
